(!) abs vsc warning light after 30 mph after battery change 09 Prius Touring
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mikeprius2, Jul 15, 2019.
  1. Mikeprius2
    Mikeprius2 Junior Member
    Hoping someone on here can help me.
    I have 2009 Prius touring. Had a 12v battery failure, so i replaced the battery.
    1. I found a ton of water in the well where the battery sits. So that concerns me.
    After i replaced the battery,
    2. (!), abs and vsc lights up after i go past 30mph. If i turn off the car, the warning goes away and doesnt come back till i step on the brakes or go past 30mph.
    I am ok with fixing cars. Can someone help me with diagnostics and what my next steps can be. I believe i have the techstream odb adapter to usb, but will need to find an old computer to use the software. Used to have it somewhere.
    Thanks in advance for the help. Im only able to work on the car on weekends, so will report back with results once i've tried it on the weekends.
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Are all 4 of your tires the same size?
    51,950
    start with a 12v health test, they don't always come fully charged.
    and make sure the connections are clean and tight, especially negative to body.
    search for rain leak threads, it is usually cracks in the rain rail underneath the black plastic, but sometimes it is the hatch hinge bolts or weatherstripping
    check your spare tire well, and the hybrid battery as well
  4. Mikeprius2
    So i got a mini-vci and the Toyota Techstream software. I got a u0124 error, loss of communication with lateral acceleration sensor module.
    That was the only error.
    All the searches i saw on here have multiple errors along with that error. Anyone know where that sensor is so i can replace it?
    Thanks.
  5. bisco
    51,950
    try the service manual at techinfo.toyota.com
  6. dolj
    dolj Senior Member
    8,448
    4,291
    Wellington, New Zealand
    What makes you think the sensor needs replacing. You have lost comms. Could be many reasons for that.
  7. fpom
    fpom New Member
    Czech Republic
    Did you solve the issue? What was that?
  8. mr_guy_mann
    mr_guy_mann Senior Member
    4,048
    1,974
    NJ-USA
    No idea if the OP fixed it as the site says he hasn't been here since that post 2-1/2 years ago.
