ABS wire sensor vs. harness
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gnome1, Mar 8, 2017.
  1. gnome1
    gnome1 New Member
    I sheared the ABS wiring on my front passenger tire. The speed sensor itself is intact but the wire connector is sheared. I have been trying to research whether I need to replace the ABS wheel speed sensor (which is much more costly) or whether I need to purchase an ABS wheel speed sensor wire harness. I am unclear on what/where the harness is located. I included a photo of the wire that is sheared, however you the sheared part is just out of the photo.
  2. DRI76
    DRI76 Junior Member
    Brawley
    Four Touring
    I am having the same issue have you corrected the problem and if so how was it fixed ?
  3. jessiejosco
    jessiejosco Member
    62
    I don't see your picture, but you could splice the wire. You don't have much to loose. It will either work or it won't. I have spliced one (not on my Prius) and it worked fine.
Loading...
