AC Button on Key Fob Doesn't Work
Discussion in 'Gen 3 Prius Technical Discussion' started by Slavatheshrimp, Jun 7, 2018.
  1. Slavatheshrimp
    116
    73
    Mather
    Remote to start and lock/unlock/alarm buttons work, but ac button doesn't. Even in 100 degree weather, with climate set to ac and solar kicking the fan, the car doesn't start even with holding the ac button on the keyfob for 2-5 seconds.
    Any help?
    #1 Slavatheshrimp, Jun 7, 2018
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    779
    308
    Maine
    I tried a few times this winter, to see if I could get it to start-up the defrost. I was never successful.
  3. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Prius by design can only be started up / on ready state, by pressing start stop button once the led on the button is solid green.
    #3 Grit, Jun 7, 2018
  4. Slavatheshrimp
    116
    73
    Mather
    my dude, im talking about the key fob not the push to start button.
  5. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    I went by your lead, "car doesn't start."
  6. Slavatheshrimp
    116
    73
    Mather
  7. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    :LOL::ROFLMAO::):LOL::ROFLMAO::)
    I’ll have to try that line with @grid next time(y).
    m.wynn, Grit, bisco and 1 other person like this.
  8. Tideland Prius
    16,611
    Is this car new to you or have you owned it since it was new from the factory? (there are different settings and maybe the previous owner changed its setting).
    If not, then it might be a faulty circuit board. Have you tried with the other remote?
  9. bisco
    52,361
    is remote start an aftermarket item?
  10. Slavatheshrimp
    116
    73
    Mather
    I got the car from an insurance auction. I will try with a second remote. But I believe it didn’t work as well.
    Yes which doesn’t come on the Prius. Remote ac does.
    #10 Slavatheshrimp, Jun 9, 2018
  11. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Since it has a dubious past, here's a guess: the FOB may not be the original and may have been only partially paired.
    Also, to verify, does the car have a solar roof/sunroof? I don't recall those being an option on level II's but I could easily be mistaken on such details.
  12. Slavatheshrimp
    116
    73
    Mather
    Yes my Prius has a solar roof and sun roof. Package 4. Both key fobs that came with the car have the ac button on it.
  13. bisco
    52,361
    are there any trouble codes stored?
  14. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Prius can't be started with stock remote, that was what I wanted to say ;)
  15. bisco
    52,361
    yes, the first line of the o/p is confusing. 'remote to start...'
  16. Slavatheshrimp
    116
    73
    Mather
    brb editing
  17. Tideland Prius
    16,611
    Alright guys, you get his point. Let's try figuring out why the Remote A/C button doesn't work.
  18. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    OP has trim II, for sure it doesn't have sun moon solar roof. Not mistaken.
  19. Tideland Prius
    16,611
    Yeah but he mentioned "package 4" in one of the posts (so I assume model IV). He may want to fix his profile to reflect his actual model.
    But you are right, a II did not have the SR option.
    fotomoto likes this.
  20. bisco
    52,361
    sounds like we may have to call on the ski-matic.:rolleyes:
