AC Compressor Question--After Wreck
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by popptj2001, Jun 9, 2016.
  1. popptj2001
    popptj2001 Member
    79
    51
    My son hit "something" with my 2007 prius and took out the condenser and radiator. No other damage I can see. I have replaced both. The car runs fine and radiator and inverter coolant circulating fine.
    My AC compressor appears to not be running. I have attempted to charge with freon with no luck with compressor turning on (after pullijng a vacuum that held fine).
    A few questions: Does the compressor turn on even at low pressures? I pulled the electrical connection for the compressor and and checked voltage from the DC inverter and show nothing across all 3 terminals.
    After hitting "something", my son drove the car home which was about 10 minutes away, so I am not sure if it ran hot. It was at night. Said he got no red triangle, and I did not notice one when I pulled it into my shop.
    How would I know for sure if the inverter is damaged? When I meter across the 3 lines and shows no voltage, does this mean it's bad? Is there a low pressure switch that turns the compressor off when freon is low?
    Any help appreciated. Im ready to roll except no cold air, and cannot have that in TEXAS!
    History: I have literally replaced just about everything at one time or another under my hood. Engine (due to chronic main seal leak), inverter, pumps, etc. I have 430,000 miles on my 07 prius and was running and cooling fine prior to the impact.
    #1 popptj2001, Jun 9, 2016
  2. Patrick Wong
    18,200
    6,493
    The pressure switch in the high pressure line will prevent the compressor from turning on if the pressure is out of spec.
    Are you using the AC volts position on your digital multimeter? The compressor is powered by 3-phase high voltage AC.
  3. popptj2001
    popptj2001 Member
    79
    51
    Checked voltage on all 3 lines and each line read 26-27 volts. (multimeter set on 200 VAC).
  4. popptj2001
    popptj2001 Member
    79
    51
    Oh, and it also reads the same thing with the AC on or off. 26-27 volts across all 3 terminals.
  5. Patrick Wong
    18,200
    6,493
    1. I assume you are measuring voltage from one terminal to the next?
    2. Use your meter to measure AC voltage coming out of a wall outlet at your home, to make sure the meter is working properly.
    3. No accident damage to the orange wiring harness to the AC compressor?
  6. popptj2001
    popptj2001 Member
    79
    51
    Thanks for your help Patrick. Yes the volt meter reads correctly in my home 120 volts.
    And no damage to the orange wiring or compressor.
    #6 popptj2001, Jun 10, 2016
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    You won't see much using a dvm. You really can't measure anything between the wires like that. There's no ground.
    You need a 3 phase power monitor to analyze 3 phase voltage and drive and pwm. Its complicated. Its 200 volts from the Invert.
    At worse you may hurt yourself and at best damage the car further.
    Its obvious the compressor is or the control wiring to the compressor. is damaged. Most likely got fod'ed when the condenser was destroyed. We have seen that many times. The ac system on a Prius is pretty complicated . And the car should be throwing multiple codes also.
  8. popptj2001
    popptj2001 Member
    79
    51
    Tks for response.
    I have examined all wiring and it wasn't touched. The condenser and radiator were pushed in but not spectacularly. Here is a pic of the damage.
    I have cautiously checked ac voltage across the lines and shows zero with ac on or off.
    I will recheck wiring.
  9. ChapmanF
    17,347
    I would back up to square one and ask the A/C system for its diagnostic codes. On a Gen 2, I think you do that on the MFD, but I don't have a Gen 2 so I can't walk out and test it. It is not something you need a scantool plugged into the OBDII port for ... more like you touch the right buttons in the right sequence while turning the car on, and it shows you code numbers (Gen 3 they show up on the heater-controls LCD of course, Gen 1 they blink on the A/C light, Gen 2 I think they show up on the MFD but you'll have to search the forums here to find the exact procedure).
    As to why your compressor isn't starting, my first three guesses are that Scotty, on the engineering deck inside the HVAC controller, is saying "Captain, I willna start the compressor under these conditions", and if you ask for the codes you'll find out what conditions he's talking about.
    -Chap
  10. edthefox5
    10,096
    4,831
    Clearwater, Florida
    No there are no diagnostic codes available on a G2 MFD. Lots of people have posted gibberish manufacturing data found on it though. You need to pull the codes using a OBDII device.
    AC faults won't be Hybrid codes unless its affected the Inverter and the Inverter is throwing a ground fault. So an auto parts store should be able to pull the ac fault codes and there will be a bunch of them but to be thorough I would get a mini vci and pull ALL the codes.
    See if any part of the Hybrid is unhappy. My guess is yes the Inverter is not happy to boot.
    I see rebuilt compressors on ebay rather inexpensive. If it was me I would stop messing around and install a new compressor and then take it to a competent ac shop and get it vac'ed down and charged up and check for leaks. Bet its got debris in the lines and bet its got leaks.
    I like to bet.
  11. edthefox5
    10,096
    4,831
    Clearwater, Florida
    Yeah stop doing that. Your not accomplishing anything. If you had the factory manual you would see numerous cautions about that area.
    Go to techinfo.toyota.com and you can rent a one day subscription of the factory service manual including all the troubleshooting tree's.
    Get your printer ready for a workout. Print out all the diagnostics for ac issue.
    The Prius ac if memory serves has a run control circuit circuit from the compressor to the Inverter that reports to the Inverter hey I'm ok...give me power. Then the INverter powers the compressor.
    If the Inverter does not see this control line report it shuts the Inverter AC power down. This all happens in about 20 msec's.
    You cannot fire up the 200 volt ac 3 phase power to the compressor without that report to the Inverter.
    Another words you cannot disconnect the power lines to the compressor and think your going to see voltage there.
    Don't work that way. There's communication there. The compressor is faulty or the wiring is damaged.
  12. ChapmanF
    17,347
    If you like to bet, would you like to bet on that?
    The procedure found in this post is: hold down the 'auto' and 'recirc' buttons on the steering wheel, while stepping on the brake and powering on the car. Wait to hear a beep and see the MFD switch to the climate control screen; look for any 2-digit codes shown in the top right corner.
    I don't have a Gen 2 to run out and try it on, but that is close enough to the procedure for my Gen 3 that I'd be inclined to believe it.
    This is not some magic answer to reading all DTCs without a scantool, it is only for HVAC codes. The repair manual will have a table referencing the two-digit codes you can see here to the 5-character DTCs you would get with a scantool.
    It is easy to make a code 21 (by placing something dark over the solar sensor on the dash), so that would be an easy way to check whether this procedure works as advertised.
    -Chap
    edthefox5 likes this.
  13. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    I just checked it out and yes, Chap, you win the bet.
  14. popptj2001
    popptj2001 Member
    79
    51
    Codes 21, 33, 41, and 72 are blinking.
    compressor: I switched the compressor out 5-6 months ago with a salvage compressor. Was running perfectly. I don't think it's the problem.
    I put a vac on the system myself and it held for 30 minutes. No leaks. Began to add freon and that's where I stopped as the compressor wouldn't start.
  15. edthefox5
    10,096
    4,831
    Clearwater, Florida
    Yep Chapman that's a good one works good. Sorry I thought you were referring to the hexi gibberish we have seen here so many times thats on the mfd.
    Mine threw a 21.
  16. edthefox5
    10,096
    4,831
    Clearwater, Florida
    You must use only special ND-11 oil in the ac system. Anything else will conduct and cause high load to Inverter.
    Go to tech info and get the ac info. There's very specific troubleshooting tips and tree's. ND-11 is the most important. You cannot use regular oil.
    popptj2001 likes this.
  17. ChapmanF
    17,347
    Also while you're at techinfo, you can look up what the codes 21, 33, 41, and 72 are telling you.
    (21 was mentioned earlier, just means the solar sensor is in the dark. It doesn't indicate a problem unless you get the code some time when sun is shining on the sensor.)
    Looking up the codes is usually where I start. I figure if the computer is trying that hard to tell me what the trouble is, no reason I shouldn't listen. :)
    -Chap
  18. ChapmanF
    17,347
    The hexi gibberish is useful for some things too, and the repair manual explains what it all means. The only thing that usually disappoints people is they discover it and think it is some complete readout for all codes in the car, when really it is only for audio, nav, and other things connected to the AVC-LAN. Usually, that isn't related to whatever problem someone is trying to solve. On the other hand, when you do have an audio, nav, AVC-LAN or gateway ECU problem, it could tell you just what you need to know. I used it plenty in my old Gen 1 when I was trying to get an iPod interface to work right....
    -Chap
  19. Patrick Wong
    18,200
    6,493
    You are supposed to add refrigerant after you have drawn the vacuum and prior to running the compressor. The correct charge is 15.9 ounces +/- 1.1 ounce. Use only pure R-134a; do not use refrigerant that contains oil unless you use the correct ND-11 oil.
    After you have done that, disconnect the 12V battery for a few minutes to clear the DTC logged by the AC amplifier. Then try to run the compressor and see what happens.
    If you get the same blink codes as before then you may need to replace the AC amplifier.
    #19 Patrick Wong, Jun 11, 2016
  20. popptj2001
    popptj2001 Member
    79
    51
    Thanks Patrick. I eventually followed that sequence with no luck. Frustrating.
    I wish there was a way to isolate and check the compressor. I'm tempted to take my compressor out and take it to my neighbors house who has a gen2 and hook it to his car, turn the ignition on and off quickly and see if it turns on....unless someone can tell me another way to check it.
