AC compressor stopped working after cross country tow
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ktravelet, May 4, 2017.
  1. ktravelet
    ktravelet Junior Member
    Philaelphia, PA
    Hi All, I recently towed my Prius from the east coast to the west coast and after getting to the destination, the AC compressor wont turn on.
    1. Does anyone have a recommended mechanic in the Bay Area?
    2. Anything I can check?
    Thanks!
  2. JC91006
    16,482
    8,400
    Does everything else work? Any warning lights on?
    Does the fan blow? Just not cold correct?
    SM-N900P ?
  3. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Not trying to question your resilience to global warming, but when was the last time it did work?
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    How was the car towed? Flatbed truck or otherwise?
    On the mfd display where you turn the ac on does the green light come on indicating the ac is on and it just has no blower fan or is the ac indicator not coming on? No green. if indicator is green its just the blower motor is bad. Thats easy see my old posts I did a write up replacing the blower motor. Common G2 issue. If no AC ON indicator then something has failed in the ac system its is detecting low pressure and it will refuse the compressor to not start to protect it. Given where its been I would inspect the front condenser for FOD damage.
    The G2 Prius will throw specific ac trouble codes on the mfd. It also may be a bad compressor that has a ac volt ground fault form leaking high voltage. If is so you will see a red triangle on the dash that's master alarm. It may disable the car but if you unbolt the 12 volt battery negative cable and then bolt it back up it resets the computer and you will be able to drive. BUT...doing that wipes all the stored codes out.
    We can do very little without the codes it will throw. Wherever you go to get it serviced make sure they harvest all the codes.
    SFO likes this.
  5. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    Beachbummm likes this.
  6. ktravelet
    Philaelphia, PA
    Thanks for the replies, here are some answers!
    - everything else works perfectly fine. No codes (checked via obII link) or lights on.
    - fan blows as strong as ever
    - honestly, I dont know the last time I used it. However, I'm pretty confident it was on once this year so far.
    - I'm not sure what AC indicator lights turn on. Will let you know tomorrow.
  7. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Without knowing how many miles on your vehicle.. guessing the best it will be a recharge, and the worst will be a new compressor.
    The light in question is on the MFD video screen, should be in the lower left corner, says AC and a tiny box will turn green when ON.
    edthefox5 likes this.
  8. JC91006
    16,482
    8,400
    There could be servo problem, where it's stuck and can't reduce temperature
    SM-N900P ?
    SFO likes this.
  9. jerrymildred
    11,511
    14,113
    Tampa, FL
    You should be able to hear the compressor if it's running and the ICE is off. Not very loud but it sounds weird.
  10. edthefox5
    10,096
    4,806
    Clearwater, Florida
    Inactivity is a sure way to kill an ac system. Let it sit unused a long time drys everything up. System will last a very long time if used daily.
    So that's why its not coming on its probably developed a leak as the seals dried up. Take the car to a car ac service center. Not the dealer.
    Just needs a charge probably. And they should inject dye and check all connections for leak.
    And its not smart to drive around all the time with no ac and the windows open its hard on the Hybrid battery all that cabin heat and moisture. The Hybrid battery Fan in the backseat is always on low to circulate air. Best air to circulate is conditioned air.
    jerrymildred likes this.
  11. Mendel Leisk
    38,728
    Using the AC once a month or so is sufficent to circulate the oil. And I think the contention that you need to run AC to keep the battery cool is mostly urban myth: I've monitored it's temps for a while with scangauge, saw little or no effect running in AC. And even on cool evenings, the battery settles in on a temp around 35C.
    SFO likes this.
  12. edthefox5
    10,096
    4,806
    Clearwater, Florida
    Maybe a myth in Canada but c'mon down here to Florida its brutally hot here and not even summer yet. Most people don't even use a windshield shade and let there cabin become ridiculously hot.
    You circulate wet super hot air in the battery case you will see alot of corrosion and shortened battery life. I'm going on 10+ years of using the my ac every minute of driving even in the winter which is a joke here. No problems so far.
  13. ktravelet
    Philaelphia, PA
    The box doesnt (and I'm not sure ever) turn green. Its outlined in yellow and has a yellow "light" in the box that turns on when the AC is on. At least thats how I think it always worked.
  14. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Got it. We might have different MFDs.
    Thought it might look like this.
    Raytheeagle likes this.
  15. ktravelet
    Philaelphia, PA
    The bottom picture is what mine looks like!
    Oh also forgot to add, miles around 165,000.
  16. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    first thing to check is the cabin filter behind the glove box
    if the car was towed odds are you had a rock or something go through the condenser and all the Freon leaked out.
    you will need to get the system pressure checked
    if theres low or no Freon in the system the compressor will not work.
    hybrids take a special Freon and oil
  17. Beachbummm
    1,160
    392
    im in florida too and never thought about it but you are right.. will be running the ac more often
