Ac compressor won’t start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Antoxen, Apr 14, 2018.
  1. Antoxen
    Antoxen New Member
    North carolina
    2006 Prius with 350k had a hole in condenser which depressurized the system. I replaced condenser evacuated system and verified vacuum hold. Added nd-11 oil to line and soaked my 34a can in hot water. Added refrigerant to low pressure side only and compressor never cut on. I’ve tried to override the pressure switch but only cut the fans on. Please advise anyone. Thanks.
  2. Patrick Wong
    18,200
    6,479
    Now that you have added some R-134a to the system, what is the pressure reading on the low side with the compressor off?
  3. Antoxen
    Antoxen New Member
    North carolina
    Pressure got to 90 psig with the compressor off.
  4. Patrick Wong
    18,200
    6,479
    How long was the car left unrepaired with the damaged condenser? Is it possible that moisture got into the compressor and damaged it?
    How much refrigerant were you able to add? The spec for the refrigerant charge is 15.9 ounces +/- 1.1 ounce.
  5. Antoxen
    Antoxen New Member
    North carolina
    4 months maybe. I may have an ounce in it if that. Is there any way to check if the compressor is done without playing the guessing game. I don’t believe in throwing parts at a problem. Can you check winding resistance to see if it is bad?
  6. Patrick Wong
    18,200
    6,479
    It seems inconsistent to me that the system 1) had a vacuum, 2) had only one ounce of R-134a introduced, and 3) has a pressure in the system of 90 psi. I think there is a problem with at least one of these findings.
    Yes, you could measure resistance across the compressor windings. If they show any connectivity to body ground, that is bad. If the resistance readings across any of the terminals differs, that would be bad. The motor is three phase AC, so the measurement of each winding should be the same, and should be isolated from body ground.
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,335
    6,011
    Columbia, SC
    This is something I'd like to learn about. I've repaired some of my other cars R134a systems, but never worked on a Prii system. Previously, after verifying the vacuum, I would just put the AC system on max and start charging refrigerant using 8 ounce cans. (Big Lots has 8 ounce cans of R134a with no additives or oil for $8 a can). Makes it easy to get close to the right charge. As you're charging, the compressor starts kicking on and off, eventually staying on once the suction (low pressure) cutoff stops activating. I don't think, at least in any of my previous work, that one ounce would be enough to even get the compressor to engage.
  8. ChapmanF
    15,883
    Have you tried asking the car yet? What's in the top left corner of the MFD if you put the car IG ON while holding auto + recirc together?
    -Chap
  9. TMR-JWAP
    6,335
    6,011
    Columbia, SC
    Now look at this...I'm about to learn something early today!!! I don't remember hearing of this previously. What information does it provide?
    Because, once I find out, I'll be experimenting on my car ASAP!!
  10. ChapmanF
    15,883
    Just a way of getting two-digit trouble codes from the HVAC, without having to lug out techstream.
    -Chap
  11. Antoxen
    Antoxen New Member
    North carolina
    I’m a pretty versed mechanic and all my readings are good. I did take resistance readings on each phase and got .08 ohms. Doesn’t say a lot because I don’t know how the motor is wired internally y or d wired. I did ask the mfd and got a 42 with a fwd arrow code. Tried to look that up with no avail. 90 psig should be enough to start the compressor. Idk. I do have 350k and just investing in a new compressor is a good idea regardless. Won’t do me any good if the compressor is not the problem though.
  12. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    Did you later on sort the problem out?
