AC issues
Discussion in 'Gen 2 Prius Technical Discussion' started by AndT, Apr 12, 2023.
  1. AndT
    AndT Junior Member
    Rochester, NY
    Hi all, long time reader, first time poster. My 2009 has been very good to me! Now at 250K miles and so far no headaches to resolve. But now I seem to have hit our first issue.
    It's spring here in Western NY and first time we needed the AC the other day, no cold air. After some observation and troubleshooting, it looks like the compressor is not engaging at all.
    I ordered a can of hybrid recharge fluid thinking maybe that would resolve the issue. Gauge on low side read low, after 1 can the meter came up to green zone on meter. But still no compressor engaging.
    I have read on here about checking the codes in system. But slight problem here... my right side steering wheel buttons don't work! So unless there is another way, can't do that. No recirc. button! Is there another way to engage the diagnostic mode?
    Any suggestions??
    I am guessing my next step is compressor repair, trying to decide if I want to attempt myself?
    Thanks for any advice!
  2. Tombukt2
    Tombukt2 Senior Member
    8,917
    1,553
    Durham NC
    Was it working last year I would think it would still be working this year sounds like to me you may be having trouble with the clock spring if partial buttons don't work on the steering wheel I don't know but that could have something to do with your air because there's buttons on the steering wheel for the climate control so before I would run and jump to start doing something with the compressor I'd want to find out if maybe it's getting signal and voltage It sounds like it's just not coming on because something over at the steering wheel isn't making a loop or whatever it needs to do I have had very little trouble with these electric air conditioning compressors in the Prius generation 2 and 3 I have gas units up that have been off and on gas for years because the people were an air conditioning types of folks you know the ones so they didn't soon as I get the car it's gassed up before I get to the gas station practically with freon in the air gas can wait far as fuel I will have my air conditioning and everything I drive farm implements and all of it
  3. ChapmanF
    15,435
    A good scan tool will work. A code like B14xy on the scan tool means the same as code xy you would see on the screen if your buttons worked.
    AndT likes this.
  4. AndT
    AndT Junior Member
    Rochester, NY
    Yeah I wondered about the clock spring. I will look into that. I did wonder if the two issues might be connected. Everything was working fine last year.
    Thanks!
  5. Tombukt2
    8,917
    1,553
    Durham NC
    That's the key right there everything was working last season That's not even been a complete year so more than likely the new event like the buttons on the steering wheel not working are probably having something to do with your issue That's why I say before I start doing a bunch of electrical work on an electric compressor. Which happened to be very reliable actually until you run them low on gas and have them spinning at 8,000 RPMs for a month and they burn up That's not the compressor's fault. If it makes you feel any better people are blowing up inverter compressors the little square air conditioning units at everybody's using now the ones that are real quiet you can sit right next to it and talk on the phone..
    AndT likes this.
  6. mr_guy_mann
    mr_guy_mann Senior Member
    3,430
    1,485
    NJ-USA
    You can get a compatible scantool to check codes and data from the HVAC control ecu.
    There can be a number of faults that prevent the compressor from engaging.
    My first thought is, how low was (is?) the system pressures? Green on the disposable gauge doesn't tell me much. A few times I have seen evaporator leaks on a Gen2 that would dump refrigerant out in a few minutes.
    https://priuschat.com/index.php?posts/3290690
    #6 mr_guy_mann, Apr 13, 2023
    AndT likes this.
  7. Tombukt2
    8,917
    1,553
    Durham NC
    Yes sir I've seen leaks that dump the gas out in a few seconds actually..but you close can . And stop dumping in . See what you need to replace do that or don't use the gas somewhere else if you have to.
  8. AndT
    AndT Junior Member
    Rochester, NY
    Hey all, still working on figuring this out. Ordered a clock spring but haven't replaced it yet. Weather has been cooler and life has been busy so it's been low priority haha.
    I was able to get the steering wheel buttons to work by turning the wheel all the way to the left. So with that, I was able get the sequence for getting diagnostic codes.
    Codes are 11 21 23
    Any tips on those? Does that help give some clues on the problem?
    And I was hoping that with the buttons working, the AC might kick on, but no... so wondering if maybe there's bigger problems here?
    Thanks for any tips!
  9. AndT
    AndT Junior Member
    Rochester, NY
    Just saw that code 21 is solar sensor, I checked at night so might just be that.
    Looks like 11 is in vehicle temperature sensor?
    23 is pressure switch?
    So any advice based on these codes?
  10. Tombukt2
    8,917
    1,553
    Durham NC
    The pressure switch is probably what's keeping the air conditioner from coming on The code for the pressure switch I don't know exactly what that means I haven't looked it up but I'm assuming it means it's not detecting any pressure in the system or something along those lines try unplugging it The plug at the pressure switch to junction block It's the air comes on I doubt it I can't remember exactly how it works when it's closed or open.
  11. ChapmanF
    15,435
    Yeah, it's a dual pressure switch, so you'll get that code if the pressure is either too high or too low. But one of those happens more commonly than the other. ;)
  12. AndT
    AndT Junior Member
    Rochester, NY
    I am stumped as to what to do here. I tried a recharge (with hybrid fluid), but without the compressor engaging it doesn't seem to help. Any point in trying another can?
    Starting to think I need to try the dealer and see what they say, running out of other ideas... any tips?
  13. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    Seen so many posts on here where the ac does not work the posters buy a can of fix a flat for your ac and surprise it does not work. Waste of time and money.
    Don't take the car to the dealer for an AC issue. Many good ac shops in your area the G2 Prius is a very common car now. They are all aware the compressor is 3 phase electric.Take it to a place that just works on car ac systems.
    Don't need to go to the dealer to learn you have a leak. Most common place for an ac leak on a G2 is the evap coil under the dash. Including mine. So don't be shocked if they tell you that save the shock for the price of e coil replacement.
    Using the search forums link up top here's some posts about an ac leak in there Prius:
    https://priuschat.com/search/437226779/?q=ac+leak&t=post&o=relevance
    AndT likes this.
  14. AndT
    AndT Junior Member
    Rochester, NY
    Thanks for the reply. I have it scheduled for a diagnostic appointment tomorrow at the dealer. Only out of desperation, tried every other option that I could find/think of. Guess will see what they come up with, probably won't pay for a major repair. Thought getting more info at least was a good next step. Wife's car and she is all done riding around in the hotbox haha. Desperate times...
    ColoradoCrow likes this.
  15. Tombukt2
    8,917
    1,553
    Durham NC
    Whatever happened with the clock spring issue If the clock spring is not correct I think that will wreak havoc on the AC system not positive of that but I think so I know in my car when the clock spring was intermittent and acting up the air conditioning was the same when I replaced the clock spring everything was restored I didn't do anything to my air conditioning system I have a generation two '09 base with ice cold air conditioning when I got the car all I did was top it off It wasn't very low but I wanted it to be where it's supposed to be making exactly the cold I needed to make like my other Toyota's here I make that happen the low side and the high side look reasonable it is very cold everything is good. When my clock spring started acting up the air conditioning started acting up I took a clock spring out of my '05 or '06 put it in my '09 after lining up the marks and everything was back to normal. So then I just left it alone and drove the car
  16. AndT
    AndT Junior Member
    Rochester, NY
    Yeah, I never got the clock spring changed, I maybe will try that depending on what I found out today. The buttons on the steering wheel did start working and it didn't change anything with the AC, so I thought maybe not related. Whatever the case, hoping for resolution soon!
  17. AndT
    AndT Junior Member
    Rochester, NY
    Well, just picked up from the dealer, AC is now working. They did a full evac and recharge along with checking everything else. They found no issues and no leaks. It's possible that the system was so low that even my attempt at recharge wasn't enough. Wish I could have avoided the cost at the dealer, but good to have it done.
    Most importantly, my wife is happy haha. Thanks again all for your input, great community and info found here.
  18. dolj
    dolj Senior Member
    7,628
    3,849
    Wellington, New Zealand
    It's also possible you ended up overcharging the system, so it is probably for the best you had the evacuation and regas done properly with the correct weight of refrigerant. Whatever price you paid, pales into insignificance when compared with having to replace the compressor.
  19. AndT
    AndT Junior Member
    Rochester, NY
    I suppose anything is possible, but I only had a small can, and it only moved the needle from near zero to the bottom range of the green zone on the meter I was using. I agree though that getting it done right is certainly worth it in this case.
