AC miraculously works again. It’s a mystery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Unclebobo, Jan 23, 2018.
  1. Unclebobo
    Unclebobo New Member
    Hawaii
    Bought a 2005 used knowing the AC compressor needed to be replaced (previous owners brought it to dealer for a fix but didn’t want to pay $3500 for the job).
    I had a backyard mechanic (i know, bad idea for a hybrid) take a look and he confirmed the compressor was done.
    I put off fixing it for a couple hot summers.
    Then, two months ago, the car gets the red triangle. I pull the code and confirm the inverter water pump needs replacing and do it myself.
    Life goes on.
    Three days ago I notice the climate is set to 78 so I turn it down and then figure, what the heck, I’ll try the AC again.
    And, it started blowing cold air.
    It’s continued to work and I hear the metallic hum of the compressor.
    A) what happened?
    B) if it stops working again, what can I tell the mechanic because it’s clearly not the compressor.
    51,155
    welcome! had you tried it previously?
  3. Unclebobo
    Hawaii
    I had tried it previously. And it didn’t work. What’s even crazier is I just now took a hill and I got the red triangle again. I pulled the code and it’s giving me the P0A93 code—inverter coolant performance. But I just replaced the cooler.
    51,155
    how is the 12v?
  5. Unclebobo
    Hawaii
    I just realized that the inverter cooler code may have been sitting in the code puller. I looked at secondary codes and it pulled up a ton saying things about right volt sensor not working etc.
    I did the 12 volt battery check as seen in another thread and with the engine off it sits at 11.9 and with the engine on it sits at 14.1.
    I will say it seemed like the main battery (the one on the display) seems like it’s been draining waaaay faster since the AC turned on and the engine has felt sluggish since the AC turned on.
    Right now it’s showing red triangle and check engine.
  6. bisco
    51,155
    you may need tech stream for the correct codes.
  7. Unclebobo
    Hawaii
    The codes are:
    C0371
    1271
    1272
    1273
    1274
    1275
    1276
    1277
    1278
    1281
    1346
    P0111
    Thank you so much for replying!
  8. bisco
    51,155
    what code reader are you using?
  9. Unclebobo
    Hawaii
    Innova 3130c
  10. Unclebobo
    Hawaii
    I believe I figured out the red triangle. The coolant drained somewhere after I parked. I assume either a leak or a crack in radiator.
    Still don’t know why the AC works.
  11. bisco
    51,155
    bad connection somewhere?
  12. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    You fixed the inverter issue. Software in the corresponding ECU cancels a/c operation if there's an inverter problem because the electric a/c compressor draws HUGE power when in use. This would quickly run down the HV battery which couldn't get a recharge because the inverter isn't working.
    You probably still have an a/c issue. Many times it's just a worn out compressor or the wrong oil/refrigerant was put in causing a short. See this current thread: AC recharge. I used the wrong fluid. Prius V 2014 | PriusChat
    #12 fotomoto, Jan 24, 2018
    m.wynn likes this.
  13. fotomoto
    5,629
    3,802
    So. Texas
    Probably have a weak HV battery too; especially if it's original.
    I think most of those are red-herrings. Suggest disconnecting 12v for a few minutes and then rescan for codes.
  14. Unclebobo
    Hawaii
    Thank you. It’s still cooling well. But it’s extremely loud.
  15. Unclebobo
    Hawaii
    Thanks for your thoughts. Makes sense. It’s still blowing cold after it restarted. It’s very very loud though. I guess I’ll see what happens.
