AC not resuming on engine restart
Discussion in 'Prius v Main Forum' started by djasonw, Oct 18, 2021.
  1. djasonw
    djasonw Active Member
    950
    116
    Coconut Creek, FL
    Here’s a strange issue I seem to be having. I’ll preface this by saying my AC works perfectly. The blower motor is relatively new and all systems seem fine. Lately, after I turn the car off, I have to manually restart the AC. I’ve always set it and forget it and it resumed as it was from the prior drive. Now I have to hit the AUTO AC button to turn it on. It also reverts to 75° even though I have it set at 68°. (I like it cold). Any ideas? I can certainly live with it, but I’m really puzzled.
    iPhone ?
  2. ChapmanF
    15,614
    Sticking my finger in the wind and saying the first thing that comes to mind: I think there are two different power circuits that feed the A/C "amplifier" (an ECU by any other name...). One is powered only when the car is IG-ON or READY, and wakes it up, and the other is powered at all times, and holds its memory.
    This sounds as if the memory (often called B+) circuit is without power, so the ECU works fine when the car is ON or READY, but wakes up with fresh defaults every time it wakes up.
    I have not sought out a wiring diagram to check my guess though.
    djasonw likes this.
  3. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Besides @ChapmanF 's concern another possibility may be the 12 V is weak. Does this also happen to the last radio station set?
    REVVL V+ 5G ?
    djasonw likes this.
  4. djasonw
    950
    116
    Coconut Creek, FL
    My 12 volt battery was changed about a year ago. I actually think the first response (thanks) is on to something. I deliberately switched back on the car about a minute after I turned it off. It resumed the AC normally. I'm wondering if this issue is a precursor of things to come. I'll keep you all posted. Again, thanks for your input. It's greatly appreciated.
    Pixel 5a ?
    Air_Boss likes this.
