Ac only blowing on high
Discussion in 'Gen 2 Prius Main Forum' started by priuslover408, Aug 25, 2017.
  1. priuslover408
    priuslover408 New Member
    San Jose, CA
    hello prius chat I have a 2005 generation 2 Toyota Prius I was using my ac when it is blowing on medium or low it will work for about 5 min but randomly cut out, however after about 2-3 minutes turn the ac off I use it on full speed (high) and it does not cutout after trying it a few times the ac blower will only work when it's on high and will not cut out. Anybody else run into this issue?
    49,594
    is it the blower, or the cold air?
  3. priuslover408
    San Jose, CA
    Blower oh and just to give everybody a heads up I replaced the blower less than 1,000 miles ago I thought it was the blower which is why I replaced it but no luck
    49,594
    maybe need a recharge.
  5. StephenJ
    StephenJ Member
    186
    Birmingham, AL
    Four Touring
    Most likely the blower motor resistor. Most of the time when they flake out the control unit can't change the blower speed, sometimes you may get 2 speeds but usually just 1, sometimes doesn't come on at all and eventually won't come on at all. If you took it to the dealer they should have been able to diagnosis that so I don't know may not be that, but I'd check it.
    #5 StephenJ, Aug 25, 2017
    GrGramps likes this.
  6. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Check the relay?
    Raytheeagle likes this.
  7. GrGramps
    GrGramps Active Member
    294
    176
    Western North Carolina
    Second the resistor. When it fails the blower motor receives the full 12 volts, then you have 2 speeds. On and off.
