AC question
Discussion in 'Gen 2 Prius Technical Discussion' started by IABoy, Aug 18, 2010.
  1. IABoy
    IABoy Junior Member
    36
    Iowa
    What technology does the Prius use for air conditioning? When parked and I want AC I don't hear any motor run except the fan when I press the AC on the MFD. And it produces cold like right now while my van and car seem to take minutes to produce anything (and they are fully freon charged).
    If the AC is freon based, then Toyota has designed the quietest running compressor system ever! I have looked under the hood but don't see the usual heavy AC hosings unless they are hidden well out of sight.
  2. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    The A/C runs on the same principle of compressing and expanding of some refrigerant fluid; the difference is that the Prius compressor runs off electricity.
  3. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
    cwerdna and IABoy like this.
  4. dogfriend
    7,512
    1,185
    Carmichael, CA
    The AC compressor is located low on the engine on the passenger (right) side as if it was belt driven, but there is no belt. The belt drives the water pump on the Gen 2 Prius, on the Gen 3 Prius, there is no belt as the water pump is electrically driven as well.
  5. actros
    actros New Member
    16
    16
    Colorado
    2003 Prius
    Yes the compressor on a Gen2 & 3 are driven by an internal 3 phase motor the supply being delivered by the DC/DC inverter, hence the orange wires going to it.
    It is of the scroll type so there are no reciprocating pistons as you would find in a similar unit on an ICE powered car.
    The unit uses R134a refrigerant as you would find in most cars on the road. HOWEVER' due to the inherent problem of moisture in A/C systems the lubrication medium mixed with the refrigerant CANNOT be PAG synthetic oil as it absorbes moisture commonly used in "other" systems.
    So the hybrid manufactures use POG oil, this lube absorbes much less moisture. As we know moisture can cause shorting down, so shorting of a three phase system (even running at a lower voltage than the traction motors) will cause an A/C shut down if the HVAC ecm "sees" a fault.
    Of particular concern is the Independant A/C shop or careless dealer that charges the system using the shop everyday recovery machine.
    Since there will always be some "carry over" of PAG oil during charging , the internals of the Hybrid system can be contaminated with this recovered absorbent PAG oil.
    For this reason alone we have a dedicated recovery/recharge machine when servicing hybrids like the Prius in my shop.
    As for running and charging the A/C the scroll compressor tends to run continuously unlike the ICE mounted compressor which is driven by the serp belt and pulses on and off according to A/C demand.
    On the hybrid the HVAC ECM modifies the a/c speed and characteristics by controlling the three phase internal motor.
    Hope that uncovers some mysteries
    Actros
    5 people like this.
  6. ctdane
    ctdane New Member
    Connecticut
    A/C Question
    Today the Air Conditioner icon at upper left of the 'Climate' screen lit up and stayed on. Sorry to ask a foolish question, but the car is now due for a periodic 5,000 mile service. If this "A/C - On" condition persists, will it cause difficulty to any systems? Thank you.
    CTdane
  7. jdenenberg
    jdenenberg EE Professor
    3,850
    1,843
    Trumbull, CT
    2020 Prius
    LE AWD-e
    That icon does not directly relate to the AC compressor. It means that the Heating/Cooling system is set on fully automatic.
    For example, manually setting the fan speed shuts the icon off even if the AC compressor is running. The automatic system will not run the compressor unless the temperature (or humidity?) in the cabin is too high for external air to lower it sufficiently.
    JeffD
  8. Dael
    Dael Member
    128
    32
    Ohio
    2020 Prius Prime
    You can turn ac in screen menu auto/off . It comes on automatically with climate. This can be disabled. We like using vents when not too hot. Although all the temps are controlled automatically, I prefer it not to turn ac on unless I tell it. It does remember last setting as well.
  9. mr_guy_mann
    mr_guy_mann Senior Member
    3,429
    1,483
    NJ-USA
    Um, you realize that you are responding to post from over 10 years ago?
    Dael likes this.
