AC stop working after winter..?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JoonohTexas, Mar 15, 2025.
  1. JoonohTexas
    JoonohTexas New Member
    Hello all.
    2024 fall time. AC worked perfectly. But after winter, it just stopped working. blower is working . it is just blowing hot air only.
    Only thing i can think of that During winter time, i changed 3 way coolant valve.
    Also i connected gauge on L side when AC is on, it does not show any pressure on gauge.
    Can i have advise on this please?
  2. JC91006
    16,651
    8,501
    You should get it charged
  3. JoonohTexas
    Is that it??
    How is this thing evaporated that much?
  4. JC91006
    16,651
    8,501
    You have a 2005? It's now 2025
    It doesn't evaporate. You probably have a slow leak. When you get it recharged, hopefully it'll get tested for leaks
  5. rjparker
    rjparker Tu Humilde Sirviente
    9,485
    5,808
    Texas Hill Country
    ACs run in winter during defrost cycles.
    ACs don't "use" or "evaporate" refrigerant. If it's low or empty it has a leak. Low (a small leak) sometimes responses to a top off charge but empty usually means a big leak which needs repair, vacuum, refrigerant oil and then refrigerant.
    There are multiple o ring seals in an auto ac that can leak as well as the inside evaporator coil.
    The condenser coil in front of the radiator can be damaged by a rock.
  6. JoonohTexas
    It leaked out fast.
    So I believe condenser might damaged.
    I will need to put some with some dye in it.
  7. Tombukt2
    Tombukt2 Senior Member
    11,994
    2,119
    Durham NC
    Yeah you can put the dye in it or you can hook up your air compressor if you have one on like 20 lb and pump some air through it and you'll hear it hissing out where it's coming from maybe you'll be able to locate it quickly like that or you can put the dye in it and have it spray all over the place and I imagine you see that for sure if it's a leak in the condenser in front of the radiator usually you can spot those pretty quickly just getting you some access to it take the front bumper cover off and have a look I mean something had to hit it a screwdriver got stuck in it something
