AC temperature from F to C
Discussion in 'Gen 3 Prius Main Forum' started by Ahmad_Basha, Sep 30, 2016.
  1. Ahmad_Basha
    Ahmad_Basha New Member
    joran
    Prius 2010 can I change temp from F to C on A/C display
  2. AzWxGuy
    AzWxGuy Weather Guy
    1,071
    549
    Tucson, AZ
    2021 Prius
    Yes, but your speedo will read out in km/h instead of mph. It's the button to the left of the radio volume knob. Above the clock adjust.
  3. Manhal K Alrashdan
    Manhal K Alrashdan Junior Member
    81
    16
    jordan
    No , you can't . But you can write a table of C and equivalent F degrees on a peice of card and hang it some where .
  4. AzWxGuy
    AzWxGuy Weather Guy
    1,071
    549
    Tucson, AZ
    2021 Prius
    Ah, you are so right. I should have tested my theory. If I remember correctly the Gen II temperature readout will change to C when the units display is toggled from imperial to metric. Maybe a Techstream variable? Either mini-VCI or dealer then.
