AC thru defrost but not front
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Jadkins35, Jun 8, 2024.
  1. Jadkins35
    Jadkins35 New Member
    Columbus, OH
    2016 Prius c
    I have a 2016 Prius C. This morning, it started only blowing cold thru the defrost vents. When I switch it to the front vents, with or without recirculation, it blows warm and humid. And I mean the defrost blows COLD. Checked to see if it needed refrigerant, the gage popped red.
  2. Leadfoot J. McCoalroller
    7,131
    6,679
    Pennsylvania
    2018 Prius c
    It's probably an issue with the air director vanes or the servos controlling them. There have been a few reports of other owners getting similarly weird behavior. Here's a thread with a related complaint that may lead you to some more info.
    Another note- you need to be extremely careful about the refrigerant level in these cars. If you are too high or too low the system loses a lot of efficiency, and can even wear out the compressor in certain circumstances.
    There is no such thing as a top-up for these cars. If you think the level is wrong, you vacuum it all out and start over.
  3. Sonic_TH
    Sonic_TH Active Member
    544
    86
    Puerto Rico
    A/C issues on the Prius C not related to the compressor, condenser, evaporator, thermostatic expansion valve, or refrigerant levels are fixed by disconnecting the 12 volt battery for like 2 minutes, then you connect it again and turn the A/C on, then turn the knob quick all the way to cool, it should work as intended there, unless you move it to hot again then it will only cool when the ICE is off. You will have to disconnect the 12 volt battery again to fix the issue.
