AC Works fine, but only if temperature is below 80 degrees outside
Discussion in 'Gen 2 Prius Main Forum' started by Raul Barraza, Jul 6, 2020.
  1. Raul Barraza
    Raul Barraza New Member
    Sacramento
    I own a 2006 Prius with 164K miles on it. I bought it about two months ago. It works runs like a dream. I use it to deliver food; Ubereats and Doordash. It is a truly special vehicle. Anyway, I am here to ask if anyone knows a reason why, my ac wont blow cold air if the temperature outside goes over 83 degrees. When the temperature outside is less than 83 degree the ac is fresh and cold as it should. I really do not know what to do. Hopefully there is someone out there with an answer :).
  2. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    You’re likely just low on refrigerant. Be careful to put the correct refrigerant in your Prius, these cars use a different type of oil than most cars do.
    When I did mine last year, I used a can without any oil at all to be on the safe side.
  3. ydpplqbd
    ydpplqbd Active Member
    551
    253
    Go to service garage that provides for free (or cheap) A/C diagnosis. Get them to write up an estimate of what is needed.
    The information that you especially want is the following:
    1.) where is the refrigerant leaking from?
    2.) is there evidence of substantial refrigerant oil leakage (if so, should be at same location as the refrigerant leak)?
    3.) can they top off the A/C system for your GEN2.
    Remember, GEN2 system capacity is as follows: i.) refrigerant capacity of 15.9oz (almost 1 pound); and ii.) 4.5 fluid ounces of ND-11 refrigerant oil.
    Also see prior thread on recharging Prius AC system: Recharging '08 Prius A/C system | PriusChat.
    #3 ydpplqbd, Jul 7, 2020
  4. ski.dive
    ski.dive Active Member
    959
    241
    Hutchinson Island,FL. Mt. Snow,VT
    Go to Walmart and buy a can of this Freon,''this freon has no other additives'' [do not get another brand] and also buy this adaptor to add the Freon
    = You probably just need a couple of 'ounces' of Freon=DO NOT OVER FILL
    #4 ski.dive, Jul 7, 2020
    ydpplqbd likes this.
  5. ydpplqbd
    551
    253
    Inaccurate posting deleted.
  6. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    Whatever you do... Don't buy recharging cans from the store, they'll make things way worse not better in the long run. Most people have a failed AC system soon after they use those cans because they aren't designed for more modern complex systems.
    To properly do maintenance on an AC system on Prius and most other modern cars where internals pressure changes based on what stage of operation the system is in you need the equipment necessary to measure air temperature & humidity outside the car, inside the cabin, as well as inside the system. That's six different measurements and that not even getting into measuring the amount of oil and refrigerant in the system, as well as other more subtle measurements.
    Spending a couple hundred dollars on servicing from someone who uses the very best gear all day every day is the way to go. @lech auto air conditionin on here has written extensively on PriusChat about what kills and what saves A/C systems and while I have no problem working on a aspect of a Prius, all his writings have convinced me this is one system I don't have the expensive equipment or experience to do correctly.
  7. ski.dive
    959
    241
    SUPER TECH 134A from Walmart =is pure 134A with no added additives- works great on the Prius A/C system
    I put some on my Prius 5 years ago and is still Cooling Perfect.
    ***Do not over fill
    Make sure you use a new adaptor and that the hose is not contaminated with another Freon.
