AC Works only when it wants to.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by VonsterMonster, Dec 15, 2015.
  1. VonsterMonster
    VonsterMonster New Member
    I'm hoping someone can help me trouble shoot my AC problem. I have a 2010 Prius and I leave the climate control on. When I start the car the AC will only work sometimes. I can run errands, where I make 5 stops shutting the engine off each time. It will be hotter then heck in the cabin and after starting the car the ac won't blow air out the vents. Sometimes I can shut the car off and restart it and then the AC will turn on. When it actually blows air, it's nice and cold. If the car is on and the AC won't work, I will turn down the climate control to the coldest setting and it still won't come on. But the next time I start the car the AC might work fine. To me, it seems like a relay or something electrical isn't turning the ac on when the car is turned on. Or maybe the blower motor is getting stuck. Please help.
    Thank you,
    Jimmy
  2. qdllc
    qdllc Senior Member
    1,371
    399
    I would try some diagnostic tests.
    When it DOES NOT WORK....
    1. Will raising/lowering the temperature setting make it kick on?
    2. Does the fan speed respond when adjusted manually?
    I'm not an expert, but if adjusting the temperature makes it turn on, I'd be puzzled as my initial guess is that your cabin temperature sensor is buggered or failing as the AC responds when the setting is outside the range of the detected temperature.
    If the fan won't respond manually, odds are something is wrong with the blower or relay setup that assigns fan speed (I had a problem a few years back on another vehicle, and it was a shorted wire(s) on the harness going to the blower).
    Good luck. Anyone have a flowchart for diagnosing the AC system?
  3. VonsterMonster
    It will not turn on by raising and lowering the temperature setting.
    The fan will not turn on when adjusted manually.
    No air comes out of the vents at all. Sometimes by shutting the car off and restarting it, the AC will blow ice cold out of the vents.
    51,151
    have you checked for trouble codes?
  5. VonsterMonster
    No I have not checked for trouble codes. There isn't any warning light on the dashboard, so I didn't think of it.
  6. bisco
    51,151
    yeah, i'm not sure either.
  7. qdllc
    qdllc Senior Member
    1,371
    399
    Does pressing buttons on the AC get a response on the LCD display or do appropriate LEDs light up?
    If not, perhaps some connector for the buttons is working loose and the default setting is OFF.
  8. Kramah313
    Kramah313 Active Member
    408
    322
    Dallas, TX
    Blower motor could be going out. This happened to me on my Corolla every few years it seemed like. When it would go out it would do this type of intermittent behavior. I could sometimes start it by hitting the bottom of the glove box a couple times.
  9. VonsterMonster
    Yes all the LCD display lights come on as everything is working correctly.
  10. VonsterMonster
    I'm starting the to think the blower motor might be going out. Sometimes when the AC works you can hear a faint helicopter noise, ta ta ta ta ta, from the vents. This is probably a dumb question, but doesn't the same blower blow the hot air out when the heater is on?
  11. Kramah313
    408
    322
    Dallas, TX
    The rattling noise was also a symptom of the blower motor for me. As far as the heat question I am not actually sure how that works. This always happened to me (of course) in the middle of the summer, which is like 110 here in Dallas so I don't know that I ever tried the heater. The good news is that the blower motor should be much cheaper to replace than the compressor or some other parts of the A/C
  12. frodoz737
    frodoz737 Top Wrench
    4,535
    2,438
    33
    Very easy DIY if this is the problem.
  13. roamerr
    roamerr Member
    135
    43
    Winston-Salem, NC
    Blower motor is common and easy replacement. If no air from vents then that's likely it.
    iPhone ?
  14. qdllc
    qdllc Senior Member
    1,371
    399
    And I don't know if this would happen so soon, but there can be an obstruction...if something built a nest in the blower motor housing. Removing the obstruction would fix the problem.
  15. SharonT
    SharonT New Member
    San Jose
    Does anyone know what to do if it IS blowing air from the outside? Here's what's going on for me: When I try to turn on the AC, the fan works, but I can't get cold air unless it's cold outside. And the display above the AC button says "Outside" instead of "AC," no matter what buttons I push. I've tried every combination. The AC button itself lights up with that little green light, but the display doesn't change. I've already had a new condenser and new freon put in, and I just noticed the display today. Somehow the button is no longer connected to whatever makes the AC work. I have a 2010 Prius. Any ideas? When you mentioned "whatever the button connects to," what DOES it connect to?
  16. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,802
    1,170
    Auburdale FL
    Enjoyed the video. Nice to see someone who knows basic electrical wiring. Was taught in auto mechanics school that a car is wired backwards. The body is hot and all the little wires grounds(yes odd Prius is using AC schema for wiring). Not sure that was for all vehicles. Do newer vehicles do that? Or is that ancient data from the civil war.
    Current flow from Car Battery - DoItYourself.com Community Forums
    Q & A: Which way do the electrons flow in a battery. | Department of Physics | University of Illinois at Urbana-Champaign
    After reading several sites I am sure I am totally confused. Must be a force field of sorts.
    #16 ETP, Apr 2, 2016
  17. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    I'm not sure I'd buy that explanation, but it's true that some circuits in some cars are wired such that one terminal of certain electrical components is connected to the "hot" (non-ground, i.e., positive) polarity even when turned off. To turn such a component on, a switch connects the other terminal of the component to the car body (ground, i.e., negative). That might seem sorta "backwards."
