ACC Battery drain
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by keith770, Apr 10, 2012.
  1. keith770
    keith770 New Member
    ruther glen, VA
    We have experience dead car, no start conditions with our 07 Prius at least 4 times. The nearest we can figure is that there is a drain when we place the cart in ACC mode, close the power windows then turn it off. This kills the car in less than 3 hours. Has this problem been noticed by anyone else. The last time the hybrid system complained about being in neutral when jumped...we NEVER use Neutral
  2. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Yeah, it sounds exactly like a weak 12V battery issue. Usually after the first time you have to jump it the battery is well on it's way. You need a new 12V battery.
  3. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
    BTW, I urge you and other owners to never use ACC or IGN ON more than momentarily. READY is your friend, it does not run down either battery, to the point of leaving you stranded.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Letting your Prius sit in ACC is just asking for a dead 12V battery; don't do it. After flattening yours four times, it's probably time for a replacement.
    The error message about being in Neutral is a red herring. A low 12V battery can cause all sorts of weird behavior, including odd messages.
    If you need to sit for extended periods, leave your Prius in Ready and Park.
    Tom
  5. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    To close the windows, it has to be in IG ON, not ACC. IG ON is a tremendous demand on the 12V battery. It is possible that you have had incomplete shutdowns from IG ON because bus voltage was not high enough to turn everything off.
    Anyway, don't bother testing or charging your 12V battery, because it has been deep cycled too many times. Just replace it.
  6. richard schumacher
    7,663
    1,040
    United States
    Ditto the 12V replacement.
    Just for curiosity, why were you doing that ACC-and-windows dance?
