acceleration loss and engine wont turn over
Discussion in 'Gen 2 Prius Main Forum' started by randall copeland, Aug 15, 2019.
  1. randall copeland
    randall copeland New Member
    itah
    so i was driving on the freeway in my 2006 prius and started to lose my power and acceleration. my fan in the back for the battery was on high. I got off and turned of the car. when i tried to start it back up the engine would putter then stall out. that happened twice. now the engine wont turn over at all. car still comes on but engine wont turn on.
  2. randall copeland
    itah
    Also in the very recent past i would press the gas and it would not accelerate. the problem would quickly go away after i stopped. the same battery fan would kick on as well.
  3. davecook89t
    davecook89t Senior Member
    1,057
    791
    Washington State, Florida
    Four Touring
    Where is the car now? I'm guessing you had it towed home. If the battery fan is loud enough for you to hear, that usually means trouble. Have you ever cleaned the fan? That would be the first thing I would check, but it is likely that you need to replace the HV battery. If you plan to keep the car, it would definitely be worth your while to get a hybrid compatible code reader and see what it says. I am using this one,
    , but there are many similar ones available online that will work just as well. You would also need to get an app for your phone, such as Torque Pro, Hybrid Assistant or Dr. Prius. After reading the codes that your car is reporting, post them here and we can help you with what should come next.
    49,574
    welcome!
    how many miles on her?
    any trouble lights?
    check the fluid movement inside the inverter fluid reservoir with the car in ready
  5. randall copeland
    itah
    269k on the miles. I was going to check for turbulence but the engine wont turn on. A light came on the touchscreen a red car with ! in the middle. I just got a new hv battery at like 190k. the fan was really dirty the guy told me. he also put a cover on the vent to help stop stuff from getting in.
  6. JC91006
    16,488
    8,402
    What is the meaning the engine would putter? Did it die after making a noise? Or you just felt there wasn't power?
  7. randall copeland
    itah
    I did have the car towed home. i will look at reader. thanks.
    the engine came on but quickly stalled out after almost stalling/putter or shacking i guess. now the engine wont start at all
    from what i saw on here it sounds like the inverter pump, but i dont know if that would stop the engine from coming on at all
    #7 randall copeland, Aug 15, 2019
  8. davecook89t
    1,057
    791
    Four Touring
    Was this a new battery from your Toyota dealer? If not, I would check to see what kind of warranty you have.
    It's possible your engine didn't really start, it was just the battery spinning it to try to start it. In that case, you many not have too many attempts left before your battery is depleted beyond redemption. What is the HV battery State of Charge that is showing on your MFD? Is there at least one bar? Unless the inverter pump also took out the AM2 fuse when it failed, a failed or failing inverter pump should not prevent your car from starting.
  9. randall copeland
    itah
    im at school but i will check and put what hv state is in when i get home. i checked the fuse for the pump it looked fine but i can change it anyway
