Accelration delayed response right after changing Transmission Oil
Discussion in 'Prius c Main Forum' started by mahmood alkhalil, Apr 7, 2018.
  1. mahmood alkhalil
    mahmood alkhalil New Member
    jordan
    2014 Prius c
    Hey everyone, i have just changed my Prius C 2014 transmission oil, and the car is acting weird right away, there is a delay when i press the gas pedal and the car response, this happened right after i changed the transmission oil. no check engine or errors appeared
    any ideas please? should i drive the car ?
    49,500
    welcome!
    what oil did you use? have you rechecked the fill level?
  3. mohsin
    mohsin Member
    91
    61
    Dubai, UAE.
    2014 Aqua
    can you pls share which oil you poured into the car (Make and Type). And the quantity (Ounce/ Ltr) poured.
    As one of the reason for the can be wrong type, and more than the quantity required.
  4. mahmood alkhalil
    jordan
    2014 Prius c
    used genuine toyota gearbox oil, it took 4.5 liters to start dripping from refill hole, and the car was sitting straight
  5. Mendel Leisk
    38,730
    Also, was the car level when refilled? Filling till it starts coming back out with the car level is the way to get the level right. Though that shouldn't be too critical. I'm also wondering what fluid was used, the specification is:
    Toyota ATF WS
    Also: was anything else done at the same time as the fluid change? Anything electrical disconnected, for example.
  6. mohsin
    mohsin Member
    91
    61
    Dubai, UAE.
    2014 Aqua
    You put in "Gearbox Oil" ? Can you post pic of the container
    4.5 ltr ? thats way too much.
  7. Mendel Leisk
    38,730
    Typo, maybe he meant 3.5? He does mention "car was sitting straight".
  8. mohsin
    mohsin Member
    91
    61
    Dubai, UAE.
    2014 Aqua
    You are right, but what confuses me is "Gear Oil"
  9. Mendel Leisk
    38,730
    Maybe just language thing. Or not. I posted the question in post #5. You're right though: completely wrong fluid could well be the issue. We wait...
