ACCESSING FOG LIGHTS 2015 PRIUS V?
Discussion in 'Prius v Accessories and Modifications' started by airgreek, Jan 11, 2019.
  1. airgreek
    airgreek New Member
    Cleveland Ohio
    2015 Prius v wagon
    Ok I looked at the bottom of my car and removed the few 10mm bolts to try and gain access to my fog lights so I can replace them with LED H11's but I must be doing something wrong because I can not removed the cover. Is this even the way to gain access to the fog lights or is there another way?
  2. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    To access Prius v fog light housings, remove the entire front undertray, and its dozen or so 10mm hold-down bolts.
  3. airgreek
    airgreek New Member
    Cleveland Ohio
    2015 Prius v wagon
    thasnk you so much I installed my LED fog lights
    Air_Boss likes this.
