Accessory outlets
Discussion in 'Gen 2 Prius Technical Discussion' started by Bernie-B, Nov 15, 2010.
  1. Bernie-B
    Bernie-B New Member
    Cheyenne, WY
    Dash Outlet not working, arm rest outlet is working. From what I get from the Owners Manual, I believe(?) there is only one fuse for both outlets. I looked at the supposed location of the fuse but it doesn't appear to have, what I call, a standard fuse, if it is a fuse. Tan colored, and appears level with the fuse box. Is there only one fuse? If not,where is the other (or both)
    actually located?
    Any inputs appreciated!:)
  2. Patrick Wong
    18,200
    6,472
    There are two fuses. See my post #4 here:
    http://priuschat.com/forums/gen-ii-...ash-12v-accessory-receptacle-not-working.html
    You'll probably need to buy replacement fuses from your local Toyota dealer parts dept because they are a special mini size that most discount auto parts stores do not carry.
