Accessory Port max voltage?
Discussion in 'Gen 3 Prius Main Forum' started by mwok86, Sep 11, 2010.
  1. mwok86
    mwok86 New Member
    203
    16
    usa
    I bought a electric tire pump that plugs into the 12v accessory port.
    Do you know how much voltage/watt the accessory port on the Prius can deliver? I read some reviews where the pump blew the fuse in the car. Also, is the Prius fuse easy to replace?
  2. JerrySC
    JerrySC New Member
    29
    SC
    10 amps according to the manual. A motor may use more current during initial start than it does running.
  3. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
    Voltage is 12V
    Current is 10A max, it will blow a fuse if you exceed 10A
    E*I=P
    12V*10A=120WATTS
  4. phoenixgreg
    phoenixgreg Senior member
    1,157
    289
    66
    Phoenix
    Maybe I have a different or updated manual, but mine says fuses #1 and #3 operate the "CIG" and "PWR OUTLET" - both rated at 15 amps. My guess is the CIG is the one forward of the low-bridge console and the other is inside the center console.
  5. mwok86
    mwok86 New Member
    203
    16
    usa
    Here are all the specs of the pump I bought:
    http://www.viaircorp.com/OffRoad/85P.html
    Can the Prius accessory port (center console and on floor port) handle that?
    It says
  6. JerrySC
    JerrySC New Member
    29
    SC
    It would appear that your pump is going to blow a fuse at pressures much above 10 psi. The pump could be run safely from a car battery or a "jump" box as long as the circuit was protected at about 20 amps. (That doesn't mean replacing the fuse in your car with a 20 amp fuse. The wiring is not heavy enough.)
  7. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Well, IF you leave the car in "ready" and IF you are lucky, you may not blow the fuse. While in "ready" the 12V system runs at 13.8V, so the pump would probably draw a little less current. Fuses are cheap. Try it -before- you need it in an emergency and see. The fuse is easy to replace.
