Accessory Screen
Discussion in 'Newbie Forum' started by bbbygbear, Oct 9, 2008.
  1. bbbygbear
    bbbygbear New Member
    New Jersey
    I have a 2008 with 4000 miles on it. When I am in accessory mode/screen, the battery is blank. Is this normal or not ? When the car is running the battery screen is fine. Any ideas out there ?:cool:
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    What is the "accessory mode screen"? I assume you are discussing the consumption or energy screen, but I'm not sure. A few more details will help.
    Tom
  3. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    I think you mean that when you hit the (POWER) button twice without your foot on the brake. This will put the car into the "accessories" mode where the radio/windows/etc will work but the car's not running.
    Yes, this is normal.
    If I'm correct, you are not using the hybrid battery in this mode and the hybrid system is not online. If this is true then the car wouldn't be able to gauge the state of the battery. I was in "accessory" mode when inflating a flat tire and managed to kill my 12v battery.
  4. bbbygbear
    New Jersey
    Yes that is it. So the battery in the screen should be blank ? Were you inflating a flat tire at a gas station or you had a portable pump you plug into the car accessory plug ?
  5. bbbygbear
    New Jersey
    thanks for your input. I got extra help from tonypschaefer.
  6. sdhanapal
    sdhanapal New Member
    Indiana
    If the car has not been in use, which battery looses power? 12V or the hybrid battery? If it is 12V how do I charge it? can a standard battery charger be used? where do I plug it in?
  7. Dozzer
    Dozzer Prius Noob
    189
    Swansea, UK
    You can plug it into the "jumper" points under the plastic cover in the engine compartment.. DO NOT reverse the polarity or you WILL probably kill the inverter and it'll cost a fortune to replace it.
    Note: when using any accessories that require power.. always put the Prius in the "READY" mode...
    The HV traction battery under the rear seats provides power to charge the little 12v battery in the back right side area.
    Using 12v power items when not in READY mode can kill the little auxilliary battery pretty quick. In "Ready" mode the vehicle will take care of the 12v aux battery and feed it a charge to keep it happy as and when needed.
