Accident...repair or not
Discussion in 'Gen 2 Prius Main Forum' started by daisy555, Mar 19, 2021.
  1. daisy555
    daisy555 Senior Member
    1,379
    579
    CT
    Hi!
    2009, 174,000 miles with new tires. : } I'm dealing with a trustworthy auto body shop and he's saying the insurance estimate for repairs is based on low value parts from Valueline not the typical certified after market parts he would usually buy. The goal was to at least negotiate for OEM bumpers but at this point that would supposedly put the car into totaled category.
    If newer used Prius's were easier to find (insurance company only gives 1-2 wks, right?), if I had a partner or neighbor to drive me around to look for a newer car and if COVID wasn't causing elevated used car prices then this might be the ideal time to hope for an insurance check. It took me 3 months to find this 2009 back in 2015. If car gets repaired, then I would have some time to shop for a newer Prius and maybe sell this one privately. There is always the age of the hybrid battery to consider. : /
    The auto body shop said they would call insurance rep and discuss upgrading to certified after market bumpers but there is very little wiggle room for additional costs.
    I always thought the insurance company either offered to repair or it was definitely totaled. Obviously the insurance company (not mine) is trying to cut their losses. Any thoughts? Anything else I should be considering? Thanks!
    49,449
    i would ask for the minimum amount from the bodyshop to make it road worthy, and pocket the balance of the insurance payment for future repairs or another vehicle.
    kenoarto likes this.
  3. daisy555
    1,379
    579
    CT
    That's what I initially had in mind but insurance company only pays supplement repair amount if repairs are done. I couldn't walk away with only $1400 knowing there was over $3000 plus worth of damage.
    49,449
    if they total it, can you buy it?
  5. daisy555
    1,379
    579
    CT
    I was wondering about that. I don't really understand how that would work. Technically they haven't totaled it. I guess they are trying to repair it with cheap parts so they don't have to total. Interesting part is that if I had been hit in the state where I live, car would definitely be totaled. I was hit across the boarder and that state has different laws for totaling a car.
  6. bisco
    49,449
    that is interesting. i had no idea it depended on what state you are in
    SFO likes this.
  7. daisy555
    1,379
    579
    CT
    My state uses 60% of value and other state uses 75%
  8. bisco
    49,449
    i don't either. but i assume you take the car instead of the check, if you know the repairs are worth it.
  9. alftoy
    alftoy Senior Member
    1,132
    509
    Saskatchewan, Canada
    Curious if you have pics of the damage and the estimate. The bumper cover difference between certified and not is not even $50, what other parts need to be replaced?
  10. ChapmanF
    15,571
    What happened with my Gen 1 was I took the car and the check. They just reduced the check (which of course was based on the pre-collision value) by the considerably smaller amount the car was worth to them as salvage.
    Such a transaction may put a 'salvage' brand on the title. The title may not be eligible to register again until that is changed to 'rebuilt', which you can do in this state by passing an inspection and proving legal sources for the parts you've used in repair. Those details surely vary between states.
    daisy555 likes this.
  11. daisy555
    1,379
    579
    CT
    Yes, the repair shop mentioned the $50 difference. I guess OEM is $100 more. I do have the estimate. How would I show you? Upload file? I was initially nervous regarding talking about it here. Insurance rep is probably not lurking but you never know.
  12. alftoy
    1,132
    509
    Upload if you can, then just delete it in an hour.
  13. daisy555
    1,379
    579
    CT
    How do you delete a post? I tried deleting one earlier and couldn't figure it out. Thanks
  14. alftoy
    1,132
    509
    Select edit to edit post and delete attachment.
  15. rogerthat
    rogerthat Active Member
    363
    118
    Georgia
    I rolled the dice after my accident (described here) and ended up buying back my 2009 salvaged car. It's been a few years since and the car has been completely trouble free (touch wood). If the salvage process is relatively easy in your state and your insurance totals the car, it might still be worthwhile for you to make them an offer.
  16. daisy555
    1,379
    579
    CT
    One more try in a few minutes. Info was cut off!
  17. daisy555
    1,379
    579
    CT
    Hope you can read it.
  18. rogerthat
    363
    118
    Georgia
    Hey Daisy, did the accident trigger any error codes? Covid disinfecting charges, c'mon!
  19. alftoy
    1,132
    509
    Minor fender bender front and back. Both bumper reinforcements are salvage, and looks like most parts specified are certified, so not sure what the body shop is getting at unless he is trying to cheap out on the parts and charge for certified. There are no Valueline parts specified so he is not being trustworthy. You can delete the pics.
    #19 alftoy, Mar 19, 2021
  20. daisy555
    1,379
    579
    CT
    No error codes and I've been driving it for a year. I'm also looking at this estimate form today and it's looking like they just changed the estimate amount and didn't categorize it as supplemental damage. Maybe because the initial estimate was based on photos.
