Accident Today - Looking for Advice
Discussion in 'Gen 3 Prius Main Forum' started by Megan76, Sep 6, 2016.
  1. Megan76
    Megan76 Junior Member
    Ventura, California
    While backing out of a parking place today (w/very little space), I managed to hit the concrete base of a lightpole. I now have scrapes along my bumper on the left corner & rear from top to bottom. The bumper is also detaching & has created a hole below the left light.
    Anyone have any advice on what to do? Where to go? I'd like to be able to just take it to Toyota & let them take care of it, but I have a feeling they would rip me off. Does anyone have enough knowledge to be able to give me an impression of what I'm looking at? Could I take it to another shop or am I going to have to replace the entire bumper? Any helpful info would be appreciated.
    (Apologies for the size of the pics. Thumbnails were too small.)
  2. matt b.
    matt b. Member
    251
    60
    L.A.
    The entire bumper is going to have to be replaced for me it's on my splitter up front that I've sustained damaged and I need to get the entire bumper replaced $380 mine is cosmetic as well but yours is more visible so go to your nearest body shop and get quotes in writing
  3. fotomoto
    fotomoto Senior Member
    5,603
    3,781
    So. Texas
    A significant portion or maybe all of that paint can be taken off with the right methods for very low costs if you can live with the other damage. BTDT with my wife (hmmmm). See below.
  4. Rebound
    Rebound Senior Member
    3,964
    2,615
    Portland, OR
    That bumper is just a single piece of vinyl. You can learn how to remove it yourself; its not hard.
    The BEST is if you find a totaled Prius that's the same color, which was totaled with front end damage. Then you just replace without painting. Otherwise, you'd have to ask your Toyota dealer if they come pre-painted.
    To be honest, you got so lucky. It's all limited to that vinyl bumper. The expensive tail light lens is fine, the metal didn't get dented. You were within 1/4" of both of those. You really lucked out.
    #4 Rebound, Sep 6, 2016
  5. bisco
    49,842
    contact your insurance company. find out what your deductible is, and if a claim will increase your premium. ask if they have a list of recommended body shops. get an estimate and make your decision. don't sweat it, we've all been there. all the best!(y)
  6. sttkailua
    sttkailua Active Member
    190
    151
    Hawaii
    Megan,
    Doesn't look that bad. At least the tail light lens is not cracked.
    I have had worst self-induced 'dents' in my years of driving.
    I did add a reverse sensor to my 2013. I can hear if I am reversing into something hidden.
    Really helps!
    It depends if it really bothers you, and how much you are willing to spend.
    Also, if you are going through your insurance company to file a claim.
    The hole is cosmetic, as water will just flow out the bottom of the bumper.
    Go to a body shop or two and see what they quote. Quotes are free!
    If it was me, I would get some matching touch-up paint and compound/sand and paint the scuffed up areas.
    A body shop would do a better job if you want to spend a few dollars.
    stt
    #6 sttkailua, Sep 6, 2016
  7. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,484
    Bay Area, California
    2019 Prius Prime
    There are plenty of salvage yards in SoCal. You can check with them and see if they have a bumper in your color. That is if it bothers you, otherwise keep driving:).
    Rebound likes this.
  8. orenji
    orenji Senior Member
    5,884
    3,486
    A new OEM bumper can be had for around $200.00, they don't come painted so you will need to get it painted, that should run you around $300 to $400, taking the old off and putting the new one on is not that hard.
    #8 orenji, Sep 6, 2016
  9. Mendel Leisk
    39,015
    I would file a claim without hesitation. That said, I'm beginning to suspect insurance is a little different in Canada.
    Our body shop would probably sand, fill and paint that.
    Very lucky hit, just the "bumper".
  10. kenmce
    kenmce High Voltage Member
    1,536
    511
    NY
    That appears to just be the bumper cover - the decorative plastic cover that sits over the working parts of the bumper. Any one can fix that, you don't need a dealer.
  11. JC91006
    16,501
    8,413
    That bumper needs to be replaced and it's very easy to take off.
    EBay sells these bumpers painted to match your car, cost is about $300. This is the cheapest way to go
  12. kenmce
    1,536
    511
    NY
    The entire bumper, or just the cover?
  13. JC91006
    16,501
    8,413
    Just the cover
  14. Okinawa
    Okinawa Senior Member
    1,333
    317
    You have a nearly new car. Get estimates from about 3 body shops and have it repaired. My Toyota dealer has a very good body shop and their rates are competitive with other body sh
  15. orenji
    5,884
    3,486
    I would only get an OEM bumper cover, the aftermarket ones don't always fit perfect.
  16. VovCA
    VovCA Member
    119
    33
    San Jose
    It looks like $400 repair (may be $700 if replace and paint), talk to co-workers, find someone who does good job for a reasonable money. Insurance won't help you, because you probably have deductible which is higher. If you were in NorCal, I could give you a contact.
