accidentally connected MG1 cable into MG2 plug hole in inverter. Am i cooked
Discussion in 'Gen 3 Prius Technical Discussion' started by Temka, Apr 14, 2025.
  1. Temka
    Temka New Member
    sweden
    i was replacing my inverterpump. and i fucked up and accidenly connected MG1 cable into MG2 plug hole. Car now stuck in check hybrid system throwing P0A08 is inventer fried? Checked now makes weird clicking noise when i try to shift in D gear.
  2. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    Having replaced the pump and incorrectly connected the power supply to MG1 and MG2, did you supply power?
    Then most likely you really have a big problem with replacing the hybrid unit.
  3. Temka
    Temka New Member
    sweden
    i connected orange MG1 cable into MG2 plug , MG2 into MG1 plug.
  4. ChapmanF
    17,949
    P0A08 is a code about the 12-volt status circuit between the DC/DC converter and the power management control ECU.
    I would suggest taking a deep, calming breath, re-checking all the connections again, and if the code persists, turning to the first page of the 23 pages of troubleshooting steps for P0A08 in the repair manual.
    Toyota Service Information and Where To Find It | PriusChat
    Brian1954 likes this.
  5. Mendel Leisk
    41,168
    The two plugs are easily reversible, ugh.
    PrimeDan likes this.
  6. ChapmanF
    17,949
    That genuinely surprises me. I remember them being radically different shapes in gen 1 ....
  7. Mendel Leisk
    41,168
    For reference:
    The harness lengths are quite different, but maybe harder to judge who’s who if the clips off.
    MAX2 likes this.
  8. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    The foolproof protection in the first generation still worked.
  9. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    With bbq sauce.
  10. Mendel Leisk
    41,168
    Repair Manual inverter install instruction has NO caution, mention of match-marks or whatever, an editorial fail:
    (Full pdf excerpt attached)
    Talk about a cautionary tale. Think I’ll put some labels on mine, for if-and-when I do the $%*# inverter water pump replacement.
  11. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    I looked. The attachment points are slightly different. There is a small protrusion.
    The question is whether there is enough strength to put it back in place, mixing up the wire harnesses from MG1 and MG2 and their attachment points.
    Mendel Leisk and Brian1954 like this.
  12. Mendel Leisk
    41,168
