Accuracy of Maintenance Required light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SteveSherman, Jan 31, 2008.
  1. SteveSherman
    SteveSherman Junior Member
    I was wondering about the accuracy of the maintenance required light.
    I currently have somewhere between 5000 and 6000 miles on this car.
    I have performed the required maintenance.
    The light comes on when I start the car but has never come on yet.
    It comes on for a few seconds and then goes out.
    I thought it should come on at 5000 miles? or is this just an estimate.
    I did use the maintenance under info and set it up for oil change and reset the mileage and date. Does this have any impact on the light?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    The starts coming on, briefly as you describe, exactly 4500 miles after the last time it was reset. At exactly 5000 miles from the last time it was reset it will light and stay lit until reset again.
  3. davidtm
    davidtm Member
    180
    TJ'ville
    Like Steve's experience, my Maintenance Req'd light never came on before I had my 5000 mi service (a little late at 5800 or so). It also lights up with the "ignition on" setting, so I know the bulb's OK. I wondered if the car can actually sense the degree of use before deciding whether to come on, as opposed to merely responding to mileage.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    yes Ed is right...I just hit exactly 4500 yesterday and saw it flash for the first time.
  5. samdaman
    samdaman Junior Member
    75
    Eastern PA
    I've had mine reset by having electrical work done at the dealer.
  6. mdotson
    mdotson New Member
    oregon
  7. I_Luv_my_Prius
    I_Luv_my_Prius New Member
    Oregon
    Thanks for the link with the information on how to turn the "Maintenance Required" light off. I just tried it and it worked. I took my Prius to Oil Can Henry's for its first oil change and shortly afterwards the "Maintenance Required" light came on. I was extremely frustrated and thought I was going to have to take my car to the Toyota service dealer to have it turned off.
    Teri
  8. harshfie
    harshfie Junior Member
    Virginia, USA
    So can I or can I not reset the maintenance light if I change the oil BEFORE the light comes on? Do I have to wait for the light to come on before I follow the reset procedure?
    Thanks.
  9. JHSmith
    JHSmith 2020 Avalon Hybrid Owner
    184
    King George, VA
    You can reset the Maintenance Light timer whenever you wish. You do not need to wait for it to come on.
