Aching noise during driving, and braking
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Claireed123, Jul 21, 2022.
Tags:
  1. Claireed123
    Claireed123 New Member
    portland
    Heyooo,
    I bought my 2010 prius about 2 years ago. I replaced my sway bar links hoping it would solve this issue but it has not. There is an aching noise coming from the front of my car when i break, and while driving. This all started happening after a slight accident where I hit someones bumper. I went under the car to check the suspension system and everything seems good to go. Any suggestions on how to repair this? I have time to work on it (I have covid) so id like to check every option before begrudgingly taking to a mechanic. Let me know!
    52,557
    welcome!
    braking could be rusty discs, but if you hear it while driving and not braking, is it constant? only over bumps? certain speed range? ev vs hv or both?
  3. PriusCamper
    PriusCamper Senior Member
    13,230
    5,352
    Pacific Northwest, USA
    Can you clarify what an "aching noise" sounds like? Is it perhaps a creaking sound you here when you press the brakes, even when car is not moving? That's common in Gen2, but probably not Gen3.
  4. Claireed123
    portland
    It is not dependent on whether its breaking. It doesn't happen when I am cruising but does constantly whenever I am driving in the city and yes going over bumps or turning.
  5. Claireed123
    portland
    Its not a creaking sound it definitely sounds like the car is aching as if there is just wear but this is definitely not normal and sounds very bad
  6. PriusCamper
    13,230
    5,352
    You're gonna have to explain the noise is better. The term aching is exclusive to living things that feel pain, not inanimate machines that make strane noises... Maybe a recording or something? I can't make sense of anything that you're saying other than the literal definition of the word:
    Definition of ache
    (Entry 1 of 2) intransitive verb. 1a : to suffer a usually dull persistent pain an aching back. b : to become distressed or disturbed (as with anxiety or regret) aching with sadness. c : to feel compassion My heart aches for those poor people. Ache Definition & Meaning - Merriam-Webster
    mr_guy_mann likes this.
  7. ASRDogman
    ASRDogman Senior Member
    7,910
    4,020
    You probably need to raise the car up on a lift so you can see it better.
    A bushing could be cracked. The struts? It could be any of several things.
    It's hard when it's on the ground.
  8. bisco
    52,557
    maybe replace all the rubber
