Acronyms and Abbreviations Glossary
Discussion in 'Knowledge Base Articles Discussion' started by hdrygas, Nov 17, 2005.
Thread Status:
Not open for further replies.
  1. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    1701a - the original Starship Enterprise - Federation USS Enterprise Class Heavy Cruiser NCC-1701a
    ABS - Anti-Lock Braking System
    AFV - Alternative Fuel Vehicles
    AT-PZEV - Advanced Technology Partial Zero-Emissions Vehicle (Meets PZEV standards and includes ZEV enabling technology)
    ASL - Automatic Sound Leveling
    Avatar - the image under usernames
    AVC-LAN - Audio Visual Communications Local Area Network uses a star style bus centered on the MFD (Multi Function Display) running at a Max of 17.8k bps connecting the components of the Audio Visual Systems including:
    Audio Head Unit
    MFD Multi Function Display
    Navigation ECU
    Gateway ECU
    B Gear - Engine Braking, (it isn't actually a gear) when you shift the transmission to this setting the engine will be used to slow down the car, it works similar to a "Jake Brake" used on the large semi-trucks (except the one for Prius is completely silent).
    BEAN - Body Electronic Area Network using a daisy chain style bus running a Max of 10k bps connecting the Body components including:
    Body ECU
    Meter ECU
    Transponder Key ECU
    Transmission Control ECU
    A/C ECU
    Power Source Control ECU
    Smart ECU
    DLC3
    Gateway ECU
    BSOC - Battery State of Charge
    CAFE - Corporate Average Fuel Economy (sales weighted average fuel economy, expressed in miles per gallon (mpg), of a manufacturer’s fleet of passenger cars or light trucks with a gross vehicle weight rating (GVWR) of 8,500 lbs. or less, manufactured for sale in the United States, for any given model year.)
    CAN - Controller Area Network using a multi star style bus connection through 2 junction connectors and connecting main bus line at 500 kbps with a max of 1M bps provides connection for the main components of the HSD including:
    HV ECU
    ECM
    EPS ECU
    Battery ECU
    Skid Control ECU
    steering angle sensor
    Yaw Rate and Deceleration Sensor
    Gateway ECU
    CARB - California Air Resources Board
    CAT - Catalytic Converter
    CBG - Cleaner Burning Gasoline
    Cd - coefficient of drag
    CEL - Check Engine Light
    Classic - The term used to identify the 2001, 2002, 2003 model years of Prius (also the 2001 in Japan only)
    CNG - Compressed Natural Gas
    CO2 - Carbon Dioxide
    CVT - Continuously-variable Transmission
    DIN - Deutsches Institut für Normung (German Institute for Standardization; similar to US ANSI)
    DLC3 - Data Link Connector 3 sits over by your right knee and allows connection with the CAN and allows for obtaining Diagnostic Trouble Codes from any of the components of the system and allows for reprogramming of ECUs
    DMV - Department of Motor Vehicles
    DRL - Daytime Running Lights (sometimes DTR Lights)
    DSP - Digital Signal Processing
    DTC - Diagnostic Trouble Code
    DVD - Digital Versatile Disc - the source disk for the navigation system, it contains the software and database for the mapping system
    E10 - a mixed fuel - 90% gasoline, 10% ethanol
    E85 - a mixed fuel - 85% Ethanol (gas blend)
    ECU - Electronic Control Unit
    ECU (expanded) - Electronic Control Unit any of the various computer control units in the car. Includes:
    HV ECU Hybrid Vehicle ECU This is the brains of the HSD receiving and sending signals from all parts of the HSD turning driver request (shift, accelerator, break) into action by parts of the HSD system.
    ECM Engine Module controls the ICE (spark, fuel injection, valve timing etc) delivering the proper amount of power to the system under direction of the HV ECU and informs HV ECU of ICE state.
    Transmission ECU after receiving On signal from HV ECU monitors the Parking Switch (button) and when pressed it locks the hybrid trans axle and locks when brake is pressed and car is placed in D, R, N
    Skid Control ECU Controls regenerative brake effect by MG2 and the hydraulic system to mimic a conventional hydraulic system as well as functions of Brake Assist, ABS (Antilock Brake System) and VSC (Vehicle Stability Control)
    ECB ECU = Electronically Controlled Brake integrated into the Skid control ECU to calculate required brake force based on peddle effort and force.
    EPS ECU = Electronic Power Steering ECU controls the power assist to steering column calculated from input from the Skid Control ECU and various sensors
    Battery ECU monitors the SOC (State Of Charge) and battery temperature communicates with the HV ECU and controls the HV battery cooling fan.
    Power Source Control ECU Controls the push button start system receives signals from switches and ECUs communicates to the HV ECU power on power off
    Air Conditioning ECU calculates the compressor speed based on input from sensors using a nonlinear fuzzy logic system controls blower speed
    Meter ECU Transmits vehicle speed signal, receives information if smart key is in vehicle and sound the warning sound in car on request of other ECUs (the source of the annoying beeps)
    Body ECU receives door lock and unlock request and monitors if smart key is in vehicle transmits this to Smart ECU over a serial connection.
    Transponder ECU Controls the HV immobilizer by recognizing the key ID code also works with Smart ECU in cars equipped with SKS. Transmits an HV stat authorization to the HV ECU
    Smart ECU Checks ID code received from wireless transponders in the car and transmits the code to the Transponder ECU
    Navigation ECU provides navigational features as well as Voice recognition and Bluetooth connection.
    Gateway ECU provides communication between the 3 LANs (Local Area Network)
    EPA - Environmental Protection Agency - a Federal group headed by the Executive Branch
    EV - electric vehicle, the EV button refers to getting the Prius into electric only mode via a control, bypassing the computer's control over the engine/motor.
    FAQ - Frequently Asked Questions
    FCC - Federal Communications Commission - controls frequencies for Homelink, Bluetooth, wireless phones and of course radio, television, satellite communications.
    FCHS - Fuel-Cell Hybrid System (Toyota's vision of the future--supposedly compatible with the THS)
    FCHV - Fuel Cell Hybrid Vehicle
    FE - Fuel Efficiency
    Fob - this is actually not an acronym but describes the electronic "key" for the Prius. Fob comes from the use of pocketwatches. At one time a man would keep his pocketwatch attached to his vest or jacket by a chain. Eventually a decorative element was added to the chain, it was called a fob. This was then adapted to mean anything decorative attached to a chain, like a key fob. Later fobs took on a utilitarian function as electronic door locks would be opened with fobs.
    GHG - Greenhouse Gas
    GPS - Global Positioning System
    H2 - Hydrogen
    HCH - Honda Civic Hybrid
    HEV - Hybrid-Electric Vehicle
    HID - High Intensity Discharge, a type of headlight
    HOV - High Occupancy Vehicle - nickname for carpool lanes in many states
    HSD - Hybrid Synergy Drive
    HV - High Voltage or Hybrid Vehicle
    ICE - Internal Combustion Engine
    IE - Internet Explorer - a web browser common on PCs, but not fully supported on Macs.
    IG-ON - when you press the Power button twice without your foot on the brake.
    IMA - Integrated Motor Assist - Honda's hybrid technology
    JPEG - Joint Photographic Experts Group - is a compressed picture file format, file can be viewed using QuickTime and web browsers
    KB - Knowledge Base
    km - kilometer
    km/H - Kilometers Per Hour
    LED - Light Emitting Diode - an alternate mode of illumination, instead of incandescent bulbs, they last longer because there is no filament that can be damaged in low impact situations and use less energy, they also light quicker when energy is applied to them but are not as bright as typical bulbs used for illumination so at this time are limited to use as brake lights.
    LEV - Low Emissions Vehicle (The least stringent emission standard for all new cars sold in California beyond 2004)
    LMPG - Lifetime Miles Per Gallon
    LOTR - The Lord of the Rings
    LPG - Liquid Petroleum Gas (Propane)
    LSD - Limited Slip Differential
    MeOH - Methanol
    MFD - Multiple Function Display (the screen)
    MG1 - the smaller motor-generator and ICE starter that is connected to the "sun" gear in the planetary gear set. It can run forwards and backwards, and under ECU control can generate mechanical force (e.g. when acting as "starter" for the gas engine) or can turn mechanical force from the engine into electricity.
    MG2 - the larger "traction" motor-generator that is connected to the "ring" gear in the planetary gear set. It can also run forwards and backwards. It is DIRECTLY connected to the front drive wheels, and can supply power to move the car, and when regenerative braking occurs it converts motion power from the wheels back into electricity.
    MIL - Malfunction Indicator Light
    MPG - Miles Per Gallon - standard measure of fuel efficiency in USA
    MPH - Miles Per Hour - standard measure of speed for cars
    MSRP - Manufacturer's Suggested Retail Price
    NAV - the navigational system option found in some Prius
    NCF - New Car Features
    NDF - Non-Documented Feature
    NiMH - Nickel Metal Hydride (battery)
    NOx - Nitrogen Oxide or Nitrogen Oxides
    NVH - Noise, Vibration, Harshness
    OBD - On Board Diagnostics
    OEM - Original Equipment Manufacturer
    PbA - Lead Acid (battery)
    PDF - Portable Document Format, file can be viewed using Adobe's Acrobat Reader (a free program) as well as most web browsers that include the Acrobat plug-in.
    PGU - Planetary Gear Unit the power transmission and distribution device of the HSG directs power between the ICE, MG1, MG2 and the wheels as directed by the HV ECU.
    PPM - Parts Per Million
    Priustoric - All that transpired before the Prius
    PSD - Power-Split-Device--the planetary gear set which divides power between the ICE and the two electric motor-generators. It also functions as the continuously-variable transmission
    PTC - Positive Temperature Coefficient
    PZEV - Partial Zero Emissions Vehicle or Practically Zero Emission Vehicle - a SULEV tailpipe emissions vehicle that has no evaporative emissions when not in use.
    RFG - ReFormulated Gasoline
    RSS - basically a fast easy way to summarize a dynamic website using formattable text that is platform independent.
    RTFM - Read The Fine Manual
    SAB - side air bags
    SKS - Smart Key System (formerly SS/SE)
    SMR - System Main Relay connects and disconnects the HV power between the HV Battery and the inverter assembly.
    SOC - state of charge, referring to the battery's state of charge when viewing the Energy screen
    SRS - Supplemental Restraint System
    SS/SE - Smart Start and Smart Entry system
    Stealth Mode - (also "EV mode") driving the Prius on electric power only
    SULEV - Super Ultra Low Emission Vehicle (90% cleaner than the average new 2003 model year vehicle)
    SUV- Sport Utility Vehicle
    THHT - Toyota Hand-Held Tester.....plugs in to OBD II interface to read car's computer codes
    THS - Toyota Hybrid System.....refers to Toyota's method of combining gas and electric power
    THS-II - Toyota Hybrid System II = Hybrid Synergy Drive
    TRAC - Toyota Rent a Car
    TSB - Technical Service Bulletin
    Turtle mode - driving the Prius with low battery, or battery too hot or two cold, so that an orange "turtle" icon shows near the speedometer, warning to avoid forceful acceleration
    ULEV - Ultra Low Emission Vehicle (50% cleaner than the average new 2003 model year vehicle)
    VIN - Vehicle Identification Number
    VOC - Volatile Organic Compound
    VSC - Vehicle Stability Control (sometimes referred to as Vehicle Skid Control), an option on the Prius that provides traction control
    XM - a brand of satellite radio
    YG - Yahoo!Group
    ZEV - Zero Emission Vehicle - Zero tailpipe emissions, and 98% cleaner than the average new 2003 model year vehicle (currently the only vehicle that qualifies is electric)
  2. Kiloran
    Kiloran New Member
    1,225
  3. mcmurray
    mcmurray Junior Member
    52
    Gold Coast, Australia
    OK, I give up - as a newbie, what does LOL mean that I see everywhere?
  4. GreenMachine
    GreenMachine New Member
    760
    Vermont, USA
  5. Tideland Prius
    16,445
    lol = laugh out loud.
    rofl = rolling on the floor laughing
    Dang, I use TRAC as traction control since that's what Toyota uses (as opposed to TCS). I'd use A-TRAC but I don't know if our Prius is equipped with that version of traction control.
  6. Kiloran
    Kiloran New Member
    1,225
    I like LMAO: Laughing my @55 off!
  7. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    I can't believe we are having this! I deal with tons of acronyms at work. My company actually has a list of acronyms, if you print that out, it's about 4 inches thick.
    I know at least one acronym is made up of other acronyms! :blink:
    I guess acronyms are wonders of the engineering world. :rolleyes:
    side note: i don't mean this list isn't good tho.
  8. Jack 06
    Jack 06 New Member
    2,556
    Winters, CA: Prius capital of US. 30 miles W of S
    Lord Of The Rings?
    Piston rings?
    Wth? :blink:
    ET Extra-Terrestrial
    MIB Men In Black
    WRUN Radio station in Rome-Utica, NY, where Dick Clark started
    Oh, and of course:
    RTFM! (Read The Fine Manual)
    Good job. :)
  9. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    Fine manual. Ah Yes, that's it. I thought it was something else. ;)
  10. Bionic
    Bionic New Member
    129
    Delaware
    That is a bumper sticker if ever I've seen one
    :lol:
  11. Oxo
    Oxo New Member
    533
    Oxfordshire, UK
  12. Jack 06
    Jack 06 New Member
    2,556
    Really. Even just the word "Priustoric". I'd buy it. Might be too subtle for some.
  13. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
  14. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    Ha funny!... thats actually what it means!.... lol = "laughing out Loud! Used very commonly in chat rooms.
    Wow... I finally found this site... can we pin this somewhere where its easier to find? Thanks to whoever started this list.
    I've been on the forum for a few days now, but I still get totally lost with the abbreviations?.... I'm sure many are intimidated to join in and talk for fear they don't have a clue what we are talking about due to the abbreviations?
    It would need to be maintained by someone or open to editing by someone"s" that can add to.
    Most topics start without prior explanations of what the terms mean... they just start using them.... then tons of other people join in and a newcomer like myself feels like a real dummy trying to ask questions?
    This is the site that really got me going.... please go there to see the references.. http://priuschat.com/-t3971.html
    Here are some abbreviations from this site alone that I don't see even on this post:
    1. TSB? - post #1
    2. TSC's - post #12
    3. NTF - post #15
    4. IMO - post #15 & 131
    5. U44 - post #21 After reading post 50, only then I realized its part of the VIN#.
    6. YG - post #24
    7. ODO - post #29 & 136
    8. SSC-40E - post #35
    9. 40D - post #35
    10. TAC - post #35
    11. IMHO - post #62
    12. ODO - post #71 Is "odometer a fair guess?"
    13. HUMU - post #86
    14. OTOH - post #100
    15. ROT (Rule of Thumb) - post #100 "thands Devils Advocate for adding the meaning. But this may still need to be added to the list.
    16. MSS: - post #164
    17. EPA - post #166 "this may not be obvious to all"
    Wow.. after reading "TSB" over and over.. I still don't know what it means? :lol:
    If I found this many abbreviations not on this list by looking only on this this one thread.. how many more are there throughout the forum?
    Just a bit overwhelming to a new person!
    We need some way that folks can add abbreviations yet the list be protected from jerks that just want to be cute.
    Maybe the moderators?... or anyone with over a 1000 posts or similiar... I don't kow the limitations of the software.
    thanks....
  15. MNPrius
    MNPrius New Member
    177
    Minneapolis
    The original was a good list, very helpful and should be put in the FAQ (Frequently Asked Questions). However, acronyms are here to stay and, IMO (in my opinion) :D you just have to plunge in and start catching onto them through inference and experience. It's not unique to this Prius forum - for example if you are a WDW (Walt Disney World ) freak and go onto their website forums you could start talking about your DH (dear Husband), the future of COP (Carousel of Progress), MS (Mission Space) and the like...
  16. windstrings
    6,280
    378
    Central Texas
    The suggestions above can only be hoped to be understood my a compilation of knowledge from months and years of browsing on forums.
    Why make the code so secret and elusive?.... that only turns people off and they leave. I"m not saying don't use the code.... because it makes for efficient communication... but give the code book too!
    I agree that many of these are used commonly in other forums.... especially "lol" thats what started this question going in the first place.
    I am not trying to bring any condemnation of any type for not having the "universal glossary of all world forums" handy......
    But I did want to point out that many of the people who have enough money to afford a nice car like the priuse have been busy workers all their life and may not be computer geeks that spend hours in chat rooms?
    I myself spend hours on the computer.. but in configuration, troubleshooting and working on them etc... And Ive been messing with computers since the 286 was moving to the 386.... I remember when I thought I was hot stuff cause I had my 3000.00 pentium 90. I remember when it was cool to have 4 meg or ram instead of 2 or even 1, like the others on the market had.
    But in all that, I have never found much interest in hanging out in chat rooms until now with priuschat! It is extremely informative but can get very technical "which I like", but the technical talks tends to get very deep in terms that are more easily expressed through "acronyms".
    I think the whole purpose of creating this forum in the first place was not so all the "experts" could talk about issues... however, I could be wrong..... I guess only Danny can answer that? But I thought it was to provide a platform for the unlearned to discuss concerns and ask questions too.
    Many have "never" been on another forum and the only reason they popped on this one was due to a google search or word of mouth etc.
    I believe Google I how I found it!
    It is after all the best resource and easiest to use for the prius..... there is another prius site out thier, but I don't feel thier software is as userfriendly as this one.
    A talented musician attracts other talented musicians... and in like manner... the more we make this user friendly for novices alike, the more the resources here will actually do some good for the public.
    Historically, forums were so complicated to use that only the computer geeks could figure them out!
    Novices.... although they can be trying.... often have very objective viewpoints that the veterans oversee.
    Anyway..... its a good resource that someone started... especially if it can be found easily....so valuable, that maybe we could even attach it to the "myassitant wizard?" also?
    Anyway its just my suggestion... and I'm pretty new to the forum..... From my viewpoint it would be very helpful.... from a veteran.. maybe not...
    But just remember..."everything" is easy once you know it!
    Ever try to put together a desk or barbecue grill etc...How about build a computer for your first time!.... its crazy the first time... then after that you could do it very quickly.....
    Sometimes it takes months for new folks to finally figure out what the heck we are talking about out here before they finally post thier first comment....and even then, they appear very shy and guarded.......
    I am a pretty technical person..so I jumped right in and asked questions even though I didn't really know what I was talking about..... and I'm sorry to say, a few jackals tried to cut me to ribbons for being so clueless....
    But many are not so brave...... why not make it easier?
  17. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I the defence of the "experts" sometimes they get into a technical discussion that is somewhat detailed and fall into these abbreviations to save time. This provides us a reference for theROU ( Mac term for the Rest Of Us) to follow these fast but very informative discussions. Over time people will learn, become informed and inform the rest of us!
  18. windstrings
    6,280
    378
    Central Texas
    Oh I know!.. and in my writing, I defended using them to promote efficiency!
    We just need a roadmap located somewhere else so we can catch up faster.
    Try reading a medical journal or a book on any subject that is different than what you are used to. Whether medical, electrical, plumbing, drafting or you name it... without a glossary it would take forever to figure it out.
    Many may take the attitude "well I had to learn it the hard way.. so can they"
    If thats your attitude, then why have you ever grabbed a manual for anything?... Aren't you glad someone made it for you?
    It kept you from having to reinvent the wheel and saved a ton of time? This forum and the lingo is very foreign to many.
    If you don't want to help in helping anyone else, thats your decision you get to make.
  19. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Medical Journal or Book I spent two years learning the vocabulary so they could teach me Medicine. I love picking up an manual for anything and learning the language. Now if I could just find some one that would send me to college for the rest of my life I would change my major every three years!
  20. windstrings
    6,280
    378
    Central Texas
    Believe me.. I tried to avoid making this suggestion...I did searches and all you find are more of the same... you can read and find 50 of them to never find the definition!
    If no one else would appreciate such a glossary I would...I myself already know about 90% of what would be in it, but I have no clue where to find the remaining 10%.
    Others may know much less... many will just give up and feel intimidated about asking and/or just leave the forum to never come back.
    Probrably the same thing you would do if you happened upon an advanced math class forum and you could not find list of the terms used.
    I'm really not trying to cause trouble... If I hear from someone in authority that its not practicle nor feasable to consider, I won't mention it again.
Thread Status:
