Active Cruise Control screen + Indicated MPG
Discussion in 'Prime Main Forum (2017-2022)' started by GrandRapidsPrime, Feb 5, 2019.
  1. GrandRapidsPrime
    GrandRapidsPrime New Member
    Grand Rapids, MI
    2018 Prius Prime
    Hi folks, just joined this forum. I drove a 2011 Prius and now upgraded to a 2018 Prius Prime. Picked it up in NJ (flew in and then drove it back which was a 12 hour road trip, but the price was worth it).
    I noticed some things I didn't care for: when driving with cruise control I was just going the speed limit and so was passed quite often and to see the active cruise control radar info constantly popping up irritated me greatly and also seems a dangerous distraction, especially at night. is there any way to turn that off? While driving things like putting a sticker over that area popped in my head, but then I want to see the 'normal screen' info.
    Also: I have started to drive to work and the distance is a bit too long to do all-electric there and back. When not driving electric I want to see the mpg I am getting while driving on gas to keep checking my driving habits and what works best. However the trip shows electric and gas mpg combined, which to me is a worthless number. Much better would be to see the miles per kWh I am getting, and a separate number for MPG. is there any way to see how I am doing on the gas part without having to set a separate trip up when I hear the ICE starting up?
  2. Biosphere
    Biosphere Junior Member
    Alberta
    2019 Prius Prime
    Bump. I am interested in this info. Any answers?
    SM-N960W ?
  3. citiprius
    citiprius Active Member
    241
    236
    51
    2018 Prius Prime
    On the small 5 inch screen, you can view the trip info by 1 or 5 miles, with either fuel (mpg) or electric (ml/kW). It's the menu right below the HV monitor. Also, your can add the "split screen" to see you current mpg/ mpkW / battery level.
    illumiN8i likes this.
  4. smyles
    smyles Active Member
    332
    229
    US
    2020 Prius Prime
    For current readings you can use a bluetooth OBD+ Torque app. Obviously, distracted driving disclaimer and all that.
  5. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    Page 233-234 in my manual. Just use the right arrow on the right hand steering wheel button cluster to scroll over to "Settings." I looks like a gear. Then scroll down to "Meter Customize."
    Screen Shot 2019-03-12 at 8.01.29 AM.png Screen Shot 2019-03-12 at 8.01.46 AM.png
  6. illumiN8i
    illumiN8i Active Member
    178
    139
    Grand Rapids, MI
    2018 Prius Prime
    @GrandRapidsPrime Good to see another fellow Prime owner in Grand Rapids!
    Sadly I haven't found a way to disable the radar pop-ups, although you can dismiss them by pressing the back button on the steering wheel. It's still worthwhile to disable the radar tutorial pop-up like @jerrymildred said, but that doesn't achieve what you asked for.
    You can view your daily average miles/kWh on the eco-diary screen on the electric daily tab, but that's your entire day, not just your current trip. Unfortunately, the eco-diary Average MPG is combined gas and electric. See page 223 in your manual.
    jerrymildred likes this.
  7. Salamander_King
    Salamander_King Senior Member
    10,975
    8,867
    New England
    For current mpg or mpkwh, as suggested by some above, use split screen on the main display. It will show a bar with that information. No absolute number display but if your car switch between HV and EV, the bar will switch between mpg and mpkwh automatically.
    jerrymildred and illumiN8i like this.
