Actual Gas Mileage Trip meter vs info screen
Discussion in 'Newbie Forum' started by loosecreek, Jan 31, 2014.
  1. loosecreek
    loosecreek Junior Member
    Just got a prius a few days ago. My info screen says I'm averaging 52 mpg. I just filled the tank and went through 1/2 tank according to the fuel gauge which is roughly 6 gallons. My trip meter says that I've gone 201 miles. Thats roughly 33.5 mpg give or take. No where even close to what the info screen says. This is my first half tank so I'll have to wait and see what happens with the rest of the tank. Thoughts? Am I missing something?
  2. Mendel Leisk
    41,592
    Yup ;)
    Once you've filled up, reset the trip meter, and for a more bullet-proof method, record the odometer reading (miles since new). Go through a tank, refill, check and reset the tripmeter (and or note the increase in odometer).
    Then divide the gallons of gas you put in by the distance travelled.
    Repeat this for a few more tanks and any errors introduced by variations in fillup will cancel out.
  3. loosecreek
    I reset the trip meter when I filled up. Time will tell as I go through the next few tanks but I am a little dubious at this point.
    52,047
    welcome to priuschat! there's no way half a tank is 6 gallons. you need to do what mendel recommends, not panic after guessing how much gas you've used. if your screen reads 52, you're probably getting around 48 or so. all the best!
  5. loosecreek
    A full tank is 11.9 gallons. Half of that is roughly 6 gallons right?
  6. fuzzy1
    10,512
    That is not how the fuel gauge reads. A few of those gallons are hidden below the last mark.
    How many gallons did the fuel pump say you put in? If you didn't look the reading on the pump or the receipt, then you CANNOT compute actual mpg.
    cwerdna likes this.
  7. loosecreek
    I don't remember how many gallons i put in. I know their were 3 bars on my fuel gauge when I filled it up. Thats a moot point if i fill the tank and reset the trip meter. Doesn't matter if the tank is almost full or completely empty. If I fill it up to 11.9 gallons and reset the the trip at a full tank then if have to go off that. At this point my trip meter says I'm averaging 33.5 and my info screen says 52mpg. I'll see what happens in the next few days.
  8. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    It's not easy to fill the tank completely, partly due to the quirky variable capacity bladder. I've never put more than 9.975 gallons into my Prius in my 8 years of ownership.
    Yes, reset the trip odometer, drive until you're nearly empty (say 2 pips, so that you have a reasonble cushion) and make a note of how many gallons you put in at that point. Calculate miles driven / gallons added to take you to "full". You'll need to average this over many tankfuls to get a reasonably accurate number, as some will be way higher than the MFD and some will be way lower..
    You may as well average the MFD values as well.
  9. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    You can't go by your first fill-up. It sounds like your trip meter and your info screen were not in sync with each other, but they should be now if you reset both at the fill-up. Let us know what your results are on the next fill-up.
    cwerdna likes this.
  10. El Dobro
    El Dobro A Member
    7,088
    3,270
    Don't forget to add your location to your info. ;)
  11. Mendel Leisk
    41,592
    Again, the trip meter can trip you up, lol. The deadliest method to record distance travelled between fillups is by recording the odometer reading, subtracting the latest from the previous. Print out your gas receipt, write the the odometer reading on it, you're good to go.
    At least on our 3rd gen, every time the car's shut down, the odometer value is displayed for close to a minute.
    cwerdna likes this.
  12. bisco
    52,047
    see what happens in the next few days and report back here. if no improvement, ignore advice and take to dealer for analysis and repair. are you under the 10 year 150,000 mile warranty?
  13. fuzzy1
    10,512
    In that case, you have absolutely no basis for figuring MPG other than what the info screen says. Period.
    The fuel gauge is a cheap crude device to keep you from running out of fuel. The top of the gauge is not at the real top of the tank, the bottom of the gauge is not at the real bottom of the tank, and the marks in between are not necessarily linear, or consistent from car to car or even tank to tank in the same car.
    If you desire an independent check on the displayed MPG -- a good idea, as those are known to shade the truth -- then you must keep track of the actual amount of fuel pumped into car. For ordinary people without a lab full of test equipment, there is no other way.
    FWIW, your model year suggests that the MPG display should be quite good. Starting with the 2010 models, they became significantly 'optimistic'.
    cwerdna likes this.
  14. El Dobro
    El Dobro A Member
    7,088
    3,270
    Now, it's called the "feel good" readout. :D
    fuzzy1 likes this.
  15. crabbyman
    crabbyman Member
    79
    30
    Yeah..I figured that out. It is to the tune of 10% or so. :whistle:
  16. bjdrums
    bjdrums Junior Member
    Temecula, California
    I use an app called Road Trip to track mileage and fuel expenses. It also allows you to record your own economy data, ave speed, temp. It gives you an idea of how much the display is off by. My actual calculated is about 1.6 - 2 mpg variance from the display.
  17. crabbyman
    crabbyman Member
    79
    30
    I just use Fuelly (as you do I see). I don't trust the trip computers. They are nice for a general idea of instataneous MPG, but long haul they are not smart enough to know you are coasting and just see it as you are getting 99+ MPG.
