Actual weight of the original16" rims ?
Discussion in 'Gen 2 Prius Main Forum' started by andreaswin, Mar 21, 2006.
  1. andreaswin
    andreaswin New Member
    72
    NORWAY
    Hi!
    ive been searching the forum for info on the weight of the rim itself.
    But seems like im only able to find info on complete Wheels.....
    im gonna get some new summer wheels/rims , and try to find some thats not heavier than the original
    anyone who knows the weight of just the rims ?
    cheers
    Andreas
  2. BMcGraw
    BMcGraw Member
    230
    Southern California
    OEM Weight: 6.5kg (14.3# ea.)
    The Goodyear Integrities weigh 17 lbs, for a total of 31.3 lbs.
    Size: 15x6JJ, PCD 100mm, 5 Holes, offset 45mm
    185/65R15's = 24.5" OD
    The Goodyear Eagle F1 DSG3s weigh 22 lbs (5 lb weight penalty).
  3. Tideland Prius
    16,445
    He wants the weight of the OEM 16"s
  4. jayway
    jayway New Member
    SF CA
    Whos got OEM 16's? Am I missing something?
  5. hycamguy07
    hycamguy07 New Member
    2,707
    Central Florida
    I have never heard of OEM 16" wheels on a Prius they come with 15's.
    We have all seen the 17" optional wheels w/tires labled 17" EFPC Wheel, which is a alloy wheel and pirelli tire combo that is installed at the dealer.
    I googled it and just got several returns regarding Prius car options...
    Ahhh, found it ! Toyota is exclusively using Enkei 16" & 17" wheels,
    Toyota has been offering the 16" optional wheels on the Matrix....
    I guess you would need to check the Enkei web site for wieght..
    I hope this helps, Good Luck! :)
  6. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    I believe the European and Asian version of Prius comes with 16" OEM wheels.
  7. Sarge
    Sarge Senior Member
    1,323
    778
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    The OP's location indicates he is in Norway, and I recall hearing the Prius is fitted with more performance-oriented tires/rims over there, but I could be mistaken.
    Unfortunately though, I do not have the answer to his question... :mellow:
    - Kevin
  8. Tideland Prius
    16,445
    Ehh,.. anywhere but NA gets 16" alloys mounted on 195/60R16 tyres (I believe they're Michelin Pilots). The also have a plastic cover like ours but while ours is a ring, theirs is an entire cover.
    andreaswin, why don't you search for the weight of those Michelin tyres then subtract that from the total weight?
  9. andreaswin
    72
    NORWAY
    yes if been thinking of that,,, was just hoping some had measured the weight of them ... il se what i can find out , and post the result
    Yes we get them with 16" as standard here.....looks nice aswell
    http://www.dinside.no/php/art.php?id=105726&bid=2
    :D Andreas
