07 here for actuator . I have a loaded 07 here that drives no codes brakes are perfect etc . If I move this actuator to the 07 I'm working on . Bleed manually no sir at bleeders anywer. Then plug up any of the scanners to bleed brakes . The bleed fails at first screen for bleed actuator removed. The car is stopped ign on acc or ready no matter. Park brake set. Autel AP tech and the GW scanner fail at same screen. Fronts squeeze up great no sir . Rears do nothing I've bled the line from master cylinder to the lil pump or stroke thing on passenger side no air I can now hear the rest brake pump beginning to clock . Wasn't before . The car scans a retrieves codes no issue 1364 5 are in play. Yesterday I also had low voltage code after charging 12V it seems ok and holding. If I put this actuator on original car which is rt here the brakes work perfect no codes at all . Other car has had no codes except low accumulator pressure no others . On original car it had a code for ripped out wheel sensor from accident. Cars still drives . Weird shiet. I'll wait a few days been in teens.
