Acura RLX sport hybrid electronic shifter...
Discussion in 'Honda/Acura Hybrids and EVs' started by Mike500, Jan 16, 2015.
  1. Mike500
    Mike500 Senior Member
    2,593
    763
    I went to the local Motor Trend sponsored auto show, today.
    Basically, it was the standard fare.
    The most interesting item is the NEW Acura RLX Sport Hybrid electronic shifter.
    Talk about complicated engineering for complication's sake.
  2. Trollbait
    11,224
    Is it just buttons of different shapes?
    Automatic shifters are already electronic. Going from a lever to buttons is actually a simplification from what I saw of the HHR shifter assembly.
  3. Mike500
    2,593
    763
    If you saw it in person, you'd be surprised...
    P for park and R for reverse requires the driver to put his or her index finger in the cavity and pull back about a quarter of an inch.
    The Prius shifter is much better. When you get used to it, flick your index finger for drive and your thumb forward for reverse. P for park requires only pushing a separate button.
  4. El Dobro
    El Dobro A Member
    6,972
    3,209
    This is what happens when engineers have spare time on their hands.
    :p
  5. Tideland Prius
    16,017
    They're sticking with it. The Acura TLX V6 with the 9-speed automatic gets the same electronic button shifter.
    It doesn't save any more space than the 4 cylinder version with its 8-speed dual clutch transmission and "traditional" shifter
