Adapting Prius C trunk for tray
Discussion in 'Gen 3 Prius Main Forum' started by elmofongo, Dec 6, 2022.
  1. elmofongo
    elmofongo Member
    256
    SF, CA
    I have a 2015 Prius C (basic trim) that doesn’t seem to accept a trunk top tray/cover (6433052410B3). Is there a way I can modify it to fit it? Maybe add the proper side panels?
    C98C8A9D-9E00-41BB-AC3C-07EB66A7C42A.jpeg B202804F-98AA-4AF6-8029-03E38FACC10C.jpeg FE6D936C-BA5C-4043-9038-617288500FE0.jpeg
  2. Tombukt2
    Tombukt2 Senior Member
    13,355
    2,405
    Durham NC
    It's the upgraded c models come with that tray pictured and has different side panels for the tray to sit on when it's hatch is closed etc then I would say all that should fit in your base c but you'll need the pieces obviously from a car that's not like the one you have which is the base would make sense to me Corollas with SR5 trim had pieces inside that the base model non SR cars didn't have I used to put those pieces in my non SR cars all the time you just had to use all the pieces together to make the whole thing look and work generally Good luck
    elmofongo likes this.
