Add an additional 8Kw battery to double the range
Discussion in 'Prime Main Forum (2017-2022)' started by Banstro, Oct 25, 2017.
  1. Banstro
    Banstro Junior Member
    PA
    Has anyone looked into or planning to mod the Prime by adding an additional 8Kw battey to the existing battery to double the range?
    52,747
    absolutely. but they all gave it up as a bad job.
    HPrimeAdvanced likes this.
  3. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    some people are never satisfied, first it was the PIP 4 KW wanted to expand to 8 KW now it's the Prime :rolleyes:
    HPrimeAdvanced and bisco like this.
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
  5. E-GINO
    E-GINO Active Member
    194
    206
    Rome, Italy
    Well... apparently the containment system did is job-... wait a minute, the pictures do not show the bottom of the Prius!
    exhuman and bisco like this.
  6. Banstro
    PA
    Adding a Toyota OEM Prius battery shouldn't be that risky. Maybe start by adding the 2012 Prius PIP 4KW battery to make it 12KW and see if it works. I understand the added weight may be counter acting on the range, but its worth a try.
  7. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    No it probably is NOT.
    Do some searching on here. I'm pretty sure that there are a couple of threads from folks who have actually tried it......or very similar.
    The problem IS mostly with the computer systems onboard that are mostly impossible to modify so that they properly recognize the extra battery capacity. If you DON'T do that, it is likely that the computers would "see" the extra battery as a fault........and the result might be exactly the opposite of what you wanted.
    priuscatprimeguy likes this.
  8. Trollbait
    12,799
    There was once several companies offering plug in kits for the Prius that did work, but it took more than wiring in more batteries.
    HPrimeAdvanced and Prodigyplace like this.
  9. Prodigyplace
    12,709
    11,847
    Central Virginia
    For the curious, the PC forum is here.
    Prius PHEV Plug-In Modifications | PriusChat
  10. ct89
    ct89 Active Member
    323
    266
    New England
    There's an economic ROI question that limits my excitement here.
    For a prime that travels 20K miles a year on electric only, assuming even as low as $0.12/KWh, you are using $500 in energy.
    For a prime that travels the same 20K miles a year averaging about 1800 miles between fill-ups, you are using about $667 in energy.
    For a commuter who is exactly 50:50 with gas/electric and could move to all electric with a 2x battery, you are currently using about $750 in energy.
    So, doubling the battery would save the 20K mile 50:50 commuter up to $250/year...Over a 10 year span, up to $2500 (assuming gas stays around $3/gal). A 2x battery is kinda a tough ROI sell in my book...
    Now compare the prime to my Highlander, and the ROI of a prime is clear...At $2000/year less to operate, I can almost pay for a prime over 10 years...That said, I like my truck.
    douglasjre and jerrymildred like this.
  11. bisco
    52,747
    yes, please give it a try, and let us know how it works out. also, if you could document with a write up and pics, that would be ever so helpful for those less knowledgeable if they want to attempt it.
    all the best!(y)
  12. Trollbait
    12,799
    On top of the of cash cost, doubling the battery is going to use up all of the cargo space.
    If electric range is your main priority, a Volt or BEV is a better buy.
  13. Prodigyplace
    12,709
    11,847
    Central Virginia
    And, even when not using the extra range, you are hauling around the extra battery weight.
  14. E-GINO
    194
    206
    Rome, Italy
    IMHO upgrading the traction battery may have sense for a non-plugin hybrid only. For instance, in an italian forum of hybrid cars I'm a member of there is a guy that firstly installed on his Lexus RX400h a 9,9 kW LiIon additional battery pack, then after a while sold the RX400h (w/o the plug in), and bought an used Lexus RX450h on which has installed the same battery pack.
    As far as I know, he's still using with satisfaction the pluginized RX , although considering the costs he supposedly beared (at least 4-5000 Euro for the battery pack and the BMS, plus installation costs) I believe that such operation was motivated more from passion and taste of the challenge than for saving money, even considering the cost of the fuel here in Europe.
    Prodigyplace likes this.
  15. Banstro
    PA
    I have a daily work commute of about 100 miles each way.. 200 miles a day.. a 1000 miles a week.. about 4K to 4.5K miles/month. If I can offset 50% of that to electric (have free charging at office location), I would definitely be saving some $$ in the long run. My 5 month old 2017 Prime is already at 22K miles. If 11K miles of that would had been just electric, I bet I would already me saving quiet a bit.
    Bob Comer likes this.
  16. fotomoto
    5,639
    3,815
    So. Texas
    OK this is a nutty, hair-brained idea but stay with me on this.
    Turn Prime on. Put car in D, proceed to nearest dealer offering double or more EV miles and trade in car. Not only will this mod be quick and easy to do, you'll get a nice, long warranty with the larger pack.
    Yeah, I know, crazy. Never mind. :confused:
  17. Prodigyplace
    12,709
    11,847
    Central Virginia
    But Tesla does not have dealers...
  18. fotomoto
    5,639
    3,815
    So. Texas
    And medical marijuana dispensaries only deal with legit patients. ;) :D
    HPrimeAdvanced and pilotgrrl like this.
  19. Trollbait
    12,799
    Why did you choose the Prime over the Volt?
    If it was for Toyota reliability, the Volt is one of Chevy's most reliable, and enlarging the battery pack could cause issues in the Prime. It will void the hybrid and battery warranty.
    If for better cargo space, the extra battery will negate that. Same in regards to cost.
    The Prime will likely still have better efficiency after this modification, but the 2.5 gallons of gas saved a week might not be worth the potential issues such a modification could entail.
  20. bwilson4web
    16,507
    Making TSS-P standard is a game changer. The honorable competition requires:
    Plug In Hybrid For Sale: 2018 Volt Pricing | Chevrolet
    • Requires "Premier" trim, +$4,000
    • Driver confidence packages, +$1,000
      • required for 'adaptive cruise control', the Chevy term
    Chevy has repeated the same mistake Toyota used to make by upscaling the trim and over charging for the predecessors of TSS-P.
    If someone is commuting 100 miles each way, every work day, TSS-P pays for itself very quickly and getting 54 MPG isn't bad either. Given New York electrical rates are averaging $0.21/kWh, it makes sense to optimize the gas performance over worry about the electrical range performance.
    #20 bwilson4web, Oct 31, 2017
    HPrimeAdvanced and Bob Comer like this.
