Add Fuel Indicator & Gas Pump Auto-stop
Discussion in 'Gen 2 Prius Fuel Economy' started by Gurgatation, Jan 28, 2010.
  1. Gurgatation
    Gurgatation Junior Member
    CA
    Does anyone know about when the "Add Fuel" messages comes up? Does it come when you have about 2 gallons left? 3?
    Also, does anyone know how much the gas pump will fill up the tank before automatically stopping? It always seems you can put more into the tank after it stops, so it doesn't seem like the gas pump will put the full 11.9 gallons into the car!
    Thanks for the help!
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    The Gen II Prius (at least in NA) uses an internal bladder that expands to hold gas and contracts to reduce evaporation. As such, it does not have a fixed size or shape. No accurate measurement will always apply, it is very temperature sensitive.
    Please do not overfill your gas tank. It often spills gas, it may contaminate your evaporative control canister and it puts more pressure on the Prius bladder. All of these will cause more gas to escape into the environment, instead of powering your car. When it clicks, it is done.
  3. JimboK
    JimboK One owner, low mileage
    2,817
    190
    49
    Chesterfield, VA
    When the "Add Fuel" light appears, many have thought, "400 miles at 50 miles per gallon must mean 3.9 gallons left." They are quite surprised when they run out shortly afterward. The other Jimbo is correct about the bladder and its idiosyncracies. Do a good search on PriusChat for related discussions.
    Meanwhile, if you happen to be one of those who likes to push the envelope on low fuel, do NOT run the car for any distance on an empty tank. That's a good way to kill your hybrid battery.
  4. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    With the last pip flashing at me the other day, mine only took 5 gallons before the pump clicked off. The attendant (we can't pump our own in Oregon) asked me how empty it was when I came in and I told her it should take more. With a knowing smile she started it again and was able to get 7.5 gallons total before it clicked off again.
    So I agree with the Jimbos - don't "top off" in the classic sense, but if it stops well short of what you expect you can just start it and wait for it to click off again.
    This is more of an issue in winter cold since the bladder is a little less flexible.
    - D
  5. dogfriend
    7,512
    1,190
    Carmichael, CA
    Yes, way after you should have already got gas. :madgrin:
  6. richard schumacher
    7,666
    1,047
    United States
    What they said. To be clear, the only "add fuel" message is when the last pip starts flashing. At that point you might be able to drive another 1 mile or another 50; there's no way to be certain.
    The bladder makes it essentially impossible to ever get 11.9 gallons into the tank. If you try you will get gasoline on your shoes.
  7. tf4624
    tf4624 Active Member
    527
    51
    I have tested many times in mine 2008.. 60-70 DEGREES OUT.. u will get about 45-50 depending on conditions till UR OUT AS IN the battery doesn't even power the car.. so the book says 3 gallons aprox. Bull ..only true if the damn tank was a tank and some plastic crap
  8. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    How many ruptured Prius bladders have been reported?...
  9. richard schumacher
    7,666
    1,047
    United States
    At least one. Prius tech galaxee documented a case a couple years ago.
  10. tam85
    tam85 New Member
    16
    illinois
    I
    your fuel will stop pumping if the fuel tank is full. so make sure that you dont try to top off the fuel pump because this will lead to spillage.
    _________
    fuel pump assembly | ~tammy beede~
  11. mark_75
    mark_75 Junior Member
    newberg Oregon
    For me it seems to not matter what time of year
    when i get to the addfuel message and fill the tank
    every time it puts about 8-\+ gallons depending
    on how far i drive with the last bar flashing
