Add used solar roof
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Frontporch, Apr 12, 2020.
  1. Frontporch
    Frontporch Active Member
    494
    107
    Nj
    Has anyone come across evidence that anyone was able to add/fabricate the factory solar sunroof to a Prius without that feature?
  2. ChapmanF
    17,326
    That would be a whole lot of fancy sheetmetal work....
  3. ASRDogman
    ASRDogman Senior Member
    7,232
    3,774
    I guess you could find a wrecked Prius with one in a junk yard and add it.
    Or order the parts from Toyota, if they are available...
    Seems like a LOT of work though.
    It would be a lot easier to get a standard solar panel and wire it in to the blower motor.
    You just need a diode so you don't provide power back through the wiring of the blower motor..
    Cheaper too! :)
    Minima Domum likes this.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    And to elaborate on that just a bit............
    The stock solar panel supplies ONLY air flow ventilation......it does not in any way charge either of the batteries.
    There are after-market "kits" with a panel to put on the dash and a little fan to put into a slightly lowered window to accomplish the same thing, supposedly, for a lot, LOT less cost and hassle.
    Minima Domum and ASRDogman like this.
  5. ASRDogman
    7,232
    3,774
    Doesn't the solar package us the blower motor? Or it is a different motor?
    It sucks in fresh cooler outside air, and the pressure blows out the hotter air through the
    vents in the trunk. Correct?
  6. sam spade 2
    7,035
    2,798
    2017 Prius c
    That is my understanding.
    Are those details somehow important ?
  7. ASRDogman
    7,232
    3,774
    All it does is keep the cooler outside air blowing through the car.
    Which helps. The temp in the car will get 125+ degrees. The outside air is 90 degrees.
    That's why you should turn off the recirculate and open the windows to help get that hotter air out faster.
    Then close the front window and leave the rear ones open a few inches for a while.
    Then as you feel it cooling you close the windows completely and turn on recirculate.
    90 degree air cools faster and easier than 125 degree air.
  8. tvpierce
    tvpierce Senior Member
    951
    881
    Maine
    2013 Prius v wagon
    I'm a big believer in window vent shades (I prefer WeatherTech in-channel), cracking the window a bit, and putting a foldable sun shade in the windshield. Low tech, low cost, and dramatically reduces the inside temperature on hot summer days.
    The first thing I buy for any car I purchase are window vent shades.
  9. ChapmanF
    17,326
    Yes and yes. :)
    The solar panel powers the blower motor in the HVAC unit when the car is off and the sun is shining.
    And models with the solar package come with a brushless motor in the HVAC unit, so as to be durable under all of the additional run hours for the blower. Models without the package have a conventional blower motor with carbon brushes.
    ASRDogman, fuzzy1 and Tideland Prius like this.
  10. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    Nope.
    The "solar vent" is a GREAT feature in warm climates. Swapping your gen 2 for a gen 3 is the easiest and cheapest way if you're looking for it to cool the car.
    If you're interested in solar charging, there's WAY more to it than that.
    Grit likes this.
  11. sam spade 2
    7,035
    2,798
    2017 Prius c
    I learned the hard way that leaving your windows cracked in Florida in the summer time is NOT a good thing to do.
    Eventually you will do that and come back to a car FULL for bugs......and maybe other critters too. :eek:
    ASRDogman likes this.
  12. ASRDogman
    7,232
    3,774
    Until it rains.. :) Then the inside gets wet.
  13. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    "Until it rains.. Then the inside gets wet."
    Actually, no, it doesn't get wet (unless you put the windows all the way down); that's the POINT of the visors: to keep the rain out when the windows are cracked an inch or so. Works great. I've had WellVisor visors on my 2010 for a couple of years. I also use the method described above for keeping the car cooler in direct sun: crack the (visored) windows and put a good-fitting window shade in the windscreen (purchased at the PC shop).
    [here in Utah, very few bugs, so that's not an issue; never've seen a bug in my car...]
    tvpierce and Minima Domum like this.
  14. ASRDogman
    7,232
    3,774
    I stand corrected. I miss read your post!
    I had those on my 1978 Corolla. I really liked them.
  15. Frontporch
    494
    107
    Nj
    Thanks for all the replies. I should have clarified. I currently own a gen 2 prius and have been wanting a gen 3 with the solar moonroof package. I don't care about the solar powered and venting so much as the open roof and I agree those window visors are awesome.
    I am part of the crowd that loves an open roof and unfortunately Toyota put that in such an expensive package, that it is kind of hard to find. I came across a Prius that needs a motor and a second wrecked Prius that has a low mileage motor and the factory moonroof. The typical moonroof is part of the stamped sheet metal. This one is so large that it appears to go from rain rail to rain rail. I do agree that there would be the front and back that are most likely visible sheet metal fabrications. Also there is whatever wiring/controls come with the roof/motor. I know a big project.. was asking more about the roof than the cooling feature.
    Thanks
  16. sam spade 2
    7,035
    2,798
    2017 Prius c
    I think that a dealership once upon a time offered to ADD a moon roof to a new Toyota for me.
    At a cost of something like $2,000.
    Given what you have said, I kind of doubt that a "factory" one could be removed and re-installed without significant damage.
  17. ChapmanF
    17,326
    The whole rear of the thing is a big solar panel that you don't need (or, probably, want) if all you're after is a moonroof that opens.
    The non-optioned Gen 3s have a 'pagoda'-shaped roof for aerodynamics; the optioned ones, not.
    I think it would be a somewhat involved bodywork project.
  18. Frontporch
    494
    107
    Nj
    Yes, I forgot about the sculpted roof on a prius.. that makes the very difficult near impossible. Thanks for the replies. Will wait till I can find one with a factory sunroof. wish Toyota had considered a moderate moonroof package. Looks like the compact prius came with that. Not crazy about that car's lines. Thanks again everyone.
  19. Grit
    Grit Senior Member
    6,450
    4,186
    Wilkes Land
    Also check for threads of exploding glasses. You’ll then saving a few thousands for additional roof related repairs.
  20. Frontporch
    494
    107
    Nj
    ? Known problems with factory solar moonroof?
