Adding additional cameras
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Paul Gregory, Jan 6, 2025.
Tags:
  1. Paul Gregory
    Paul Gregory Senior Member
    2,154
    564
    Alberta
    2024 Prius Prime
    XSE
    I installed 2 additional cameras on my Gen 3 2012 Prius Plug in. I wanted to be able to see in front, so I wouldn't keep hitting the parking slab. It made an awful noise as the front spoiler buckled under the vehicle. I also installed one under the passenger side mirror, to see how close I was parking to the curb. There was a convenient video input jack on the back of the head unit, but it would only accept input from the cameras when the car was rolling and in reverse. So the trick was to put the car in reverse, apply the brake while the car was still rolling, and switch the inputs to the appropriate camera. That made it a bit awkward to use, but there was a commercial solution available that provided pulse code modulation to the head unit, to fool it into think the car was rolling in reverse. I never went that route, so I left it that way; still useable, but awkward. Eventually the head unit failed and had to be replaced. I suppose if I were to do it over, I'd install a separate display screen.
    Pd30242 likes this.
  2. Pd30242
    Pd30242 Junior Member
    25
    Chicago
    I have a live view backup cam on my second gen to help me see without side mirrors. It was dirt cheap, easy to wire and works great. I have the display screen screwed right on to the dash.
  3. MrPete
    MrPete Active Member
    500
    190
    Colorado, USA
    My simple solution for "virtual reverse":
    • I added a switch to the dash,in a blank spot next to the side view mirror controls.
    • Switch OUT is "reverse" to whatever head unit or display you have
    • Switch IN when down: the actual reverse signal
    • Switch IN when up: +12 volts.
    Thus,with the switch flipped up, the display immediately shows camera(s)
