Adding Android Auto
Discussion in 'Prime Audio, Electronics, and Infotainment' started by Graphicsop, Feb 21, 2022.
  1. Graphicsop
    Graphicsop New Member
    New Jersey
    2022 Prius Prime
    I just purchased a 2022 Prius Prime. I was told ir has Android Auto, but it does not. Is there something I can buy to get Android Auto to work with Android 12 & a 2022 Prius Prime?
    49,504
    a new head unit
  3. Graphicsop
    New Jersey
    2022 Prius Prime
    What does that mean?
    49,504
    aftermarket radio that android auto capability
  5. Graphicsop
    New Jersey
    2022 Prius Prime
    Could you be more specific?
  6. bisco
    49,504
    i can't. but you could check around at audio shops and places like crutchfield
  7. MalachyNG
    MalachyNG Active Member
    300
    221
    Northern NY
    2022 Prius Prime
    Only LE trim has Android Auto. The 11" screen on the XLE and Limited trims only supports Apple Carplay.
    There are some dongles you can buy that are little android PCs that'll trick the system into thinking it's an iphone running carplay so you can get android auto like features.
    I know at least 1 person who reported success using it with their new '22 Prime with the 11" screen. He posted in a Prime owner Facebook group with photos.
    He had this device
  8. Marine Ray
    Marine Ray Senior Member
    1,139
    941
    Sparks, NV
    In regards to recent discussion on Facebook Prius Prime Owners Group. Looks like it only works if PP has ApplyCar Play. So, 2020 and newer PPs.
  9. MalachyNG
    300
    221
    Northern NY
    2022 Prius Prime
    That's true. The device won't be able to add carplay or Android Auto if your head unit doesn't already support Carplay.
    It can add Android Auto to the big 11" screen by convincing the head unit it's an apple device connected through carplay. How long apple and/or Toyota may support a workaround like that remains to be seen.
    Marine Ray likes this.
  10. Graphicsop
    New Jersey
    2022 Prius Prime
    Thank you. I'm looking into this.
  11. Marine Ray
    1,139
    941
    Sparks, NV
