Adding courtesy lights on rear doors.
Discussion in 'Gen 3 Prius Audio and Electronics' started by Raphael Muscarelle, Nov 20, 2019.
  1. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    I've had these LED courtesy lights that can attach to underside of door. I haven't installed them becouse I'm worried about where to hook them into the open door light system.
    Any suggestions?
  2. Mendel Leisk
    38,726
    Test the wires leading from these:
    (Looks like a Torx head screw holding it?)
    If a wiire's got 12 volts only when the door's open, you're in business. A simple 12 volt test probe is all you need to verify. Look like this:
    Attach the alligator to a grounded bolt or metal, then probe the wire's connector: if there's 12 volts it'll flow through, light bulb in the probe's handle.
    Or a multimeter in DC volts mode.
    That said, maybe it's preferable to find a similar wire inside the door, so you don't have run additional wire out along the umbilical between body and door. Not sure if there'd be one on the back doors though.
    #2 Mendel Leisk, Nov 20, 2019
  3. DimitrisTS
    DimitrisTS Junior Member
    27
    49
    Thessaloniki
    There is just one cable behind this black switch and its the ground.
    So you can connect a bulb with a permanent 12v from somewhere and the ground from this switch.
  4. Raphael Muscarelle
    661
    222
