adding cruise to a non cruise 2004
Discussion in 'Gen 2 Prius Accessories & Modifications' started by prius2go, Jul 22, 2007.
  1. prius2go
    prius2go Member
    311
    is it just a button?
  2. jdenenberg
    jdenenberg EE Professor
    3,850
    1,843
    Trumbull, CT
    2020 Prius
    LE AWD-e
    <div class='quotetop'>QUOTE(prius2go @ Jul 22 2007, 04:24 PM) [snapback]483238[/snapback]</div>
    Where did you find a non-cruise control 2004 Prius. Mine was a base (no option package Prius and CC was standard equipment.
    I have seen some discussion about adding CC to a Clasic (2001-2993) Prius.
    JeffD
  3. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(jdenenberg @ Jul 22 2007, 03:40 PM) [snapback]483294[/snapback]</div>
    From looking at prius2go's profile, it would appear that he found it in Great Britain.
  4. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    I don't think it's just a button. It think it would likely be horrendously expensive and extremely difficult to do.
  5. statultra
    statultra uber-Senior Member
    796
    30
    Edison,NJ
    2001 Prius
    behind the front drivers airbag theres a plug
    that you stick a wire in to a switch that has 4 resistors ( cruise on off, set , resume, and the other one that has no name ) that go to the ground the specs are in the electrical manual for the prius i can retrieve it.
  6. otrebor
    otrebor Junior Member
    <div class='quotetop'>QUOTE(statultra @ Jul 23 2007, 06:36 PM) [snapback]483608[/snapback]</div>
    Have you better infos or images? I have no cruise but could be interested in adding if not so difficult/expensive/intrusive....
