Adding LED Strip to Hatch. How to Tap Into Wiring For Rear Lights?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Ragz, Mar 25, 2021.
  1. Ragz
    Ragz Active Member
    210
    110
    New York
    not sunroof related
    looking to add a led strip below the rear hatch, how do i gain access to the rear wiring for lights/ blinker. stop light?
    Thanks
  2. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    There is a little cover on the inside next to the light assembly.
  3. Ragz
    Ragz Active Member
    210
    110
    New York
    right by the gas tank opening?
    i thought that was it
    just unwrap those wires and i can match them up?
  4. Maarten28
    415
    224
    Netherlands
    In this video you see the cover that I mean:
    I don't know if you have a constant 12V from the rear light assembly and also don't know if you want to put in on the inside or outside. I assume inside for opening the hatch? Why not wire it through to the existing trunk light?
  5. Ragz
    Ragz Active Member
    210
    110
    New York
    i want to connect to blinkers, stoplight and regular lights
  6. amarino
    amarino Active Member
    138
    102
    99
    #6 amarino, Apr 7, 2021
