Adding LED strips underneath the Prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Miguel Olivares, Dec 6, 2019.
  1. Miguel Olivares
    Miguel Olivares Junior Member
    56
    Oakland
    Hi all. I love my Prius and I love green LED lights!
    I want to add Green LED strips underneath my car. The problem is, I only want them to turn on whenever I turn on my headlights.
    how do I go about this ??
    I was able to successfully install the same led strips to the side doors since the light only turns on when I open them.
  2. Davidude
    Davidude Junior Member
    94
    Georgia
    Ensure you look up your local laws regarding underglow lights, in some areas any colors other than white is illegal to have. I imagine if you connect the power to the fuse box you could power it with another switch, so you don't always have to run the green lights.
  3. frodoz737
    frodoz737 Top Wrench
    4,719
    2,517
    33
    ...green LEDs under a GEN II Prius...in Oakland? The State's Vehicle Laws will be the least of his worries.
  4. Davidude
    94
    Georgia
    Didn't realize his location, California apparently doesn't care as long as you have no red lights in the front of your car so OP is fine with whatever he does.
  5. Miguel Olivares
    56
    Oakland
    do tell more, is this the relay box in the hood or the one under the steering wheel?
  6. Davidude
    94
    Georgia
    You could use either, whichever is easiest. They do the same thing, just different places. If it's on the outside of your car, probably easiest to use the engine fuse box.
  7. Storm88000
    Storm88000 Active Member
    321
    145
    LHValley, PA
    2020 Prius Prime
    The cat will suddenly disappear. lol. Yeah my mom always told me that with your car, keep a low profile :)
