Adding USB ports to center console
Discussion in 'Gen 2 Prius Audio and Electronics' started by david81, Apr 26, 2008.
  1. david81
    david81 New Member
    62
    NE Ohio
    What do you experts out there think about hardwiring some USB ports into the center console?
    With all the gadgets that take a standard USB cord for power (Treo, Bluetooth GPS, Bluetooth earpiece, Ipod, etc) why not get rid of the "cigarette lighter" adapter and just integrate the ports directly.
    Seems like it should be relatively simple. Just grab the 12v from the line going to the outlet, feed it into the circuit that's already in a USB car adapter
    2-Port USB Car Charger Adapter : Audio & Video from Overstock.com
    then send it to some nice panel mount ports.
    FRONTX - Panel Mount Dual USB 2.0 Internal Cable - bulkhead USB type A female to header (pinout)
    Any thoughts?
    David
    kiwiminime likes this.
  2. rpiereck
    rpiereck Regenerator
    289
  3. BFAyer
    BFAyer Junior Member
    Gloucester, VA.
    All you need is a: +5V Fixed-Voltage Regulator 7805 from radio shack and a panel mount. I have been searching for a nice panel mount. All the ones I have found so far are like the one above. I am looking for something a little more finished.
    I all ready have dual 12v outlets I have wired in below the radio. The USB would go right under them.
  4. patsparks
    10,664
    567
    Adelaide South Australia
    Why not use a powered 4 port hub and a 12v to 5v universal power adapter? Stick the hub inside the centre box with velcro so the USB ports are facing up.
    I'd love to have USB connectivity with the MFD and stereo, how cool would that be!
