Additional maintenance
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by JorgeLA, Jun 10, 2019.
  1. JorgeLA
    JorgeLA New Member
    Morelia
    Hey there
    Hope you all are doing alright. This is my first post. My Prius 2016 just got seventy thousand km. My dealership is recommended me 2 additional services (besides the regular maintenance):
    1) Internal combustion service (150 usd)
    2) Transmission service (200 usd)
    Do that even make sense? I think that a Prius is quite different in terms of transmission and combustión, so are those services required (or even recommended)? Or is it just my dealership trying to make money (fraudulent) from me?
    Many thanks for your time!!
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,589
    near Brisbane, Australia
    Welcome to PriusChat
    Personally, I'd ignore them, particularly the first - unless
    1) it's in the service schedule (I can't spot it in the Australian schedule);
    2) it's broken - which it isn't; or
    3) you plan on keeping it for a REALLLLY long time, like 500,000km - maybe the Transmission service?? - I know some on PriusChat have suggested it. Though, in 3½ yrs on PriusChat, I've not heard of a Transmission which failed.
    To be honest - I have no idea what they're talking about with "Internal Combustion Service". Sounds dodgy to me.
    JorgeLA, bisco and krmcg like this.
    51,141
    ^^^agreed^^^ if you want to keep it for more than 150,000 miles, it might be worth doing a tranny oil change, but that shouldn't be more than $100.or so.
    JorgeLA likes this.
  4. JorgeLA
    JorgeLA New Member
    Morelia
    Many thanks to both of you for your help. Sometimes it's really hard to figure it out whether is a scam or something worthy. Again, thanks!
    So, I would (perhaps) consider just the additional transmission service...
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    I imagine that the "transmission service" is simply changing the fluid. That's easier than changing the oil. Lots of threads here on how to do that. Don't let them feed you garbage about a flush. There's no such thing with the Prius transaxle with is nothing like a typical transmission.
    An engine service could be almost anything.
    alanclarkeau and JorgeLA like this.
  6. alanclarkeau
    7,045
    7,589
    I just had a discussion with a friend who has just bought a Direct Injection vehicle. Since buying it, he's having "Buyer's Remorse" when he read something about problems with buildup around the inlet valves of DI engines. I did a bit of googling - and there is mention in a couple of places about a Combustion Chamber service for DI engines - which, seemingly seems more relevant to older designs.
    I wonder if the OP's Dealer has no idea that a PRIUS is Sequential Multi-Port Injection, not DI?
    jerrymildred and JorgeLA like this.
  7. Mendel Leisk
    40,574
    Both "services" seem vague, likely intentionally.
    The "transmission service" if it indeed is a transaxle drain-and-fill, should be around $80, definitely no more than $100.
    The other, I'd waive, especially if that's all the info they provide. Could be anything.
    kithmo and JorgeLA like this.
  8. kithmo
    kithmo Couch Potato
    2,404
    2,774
    47
    South Yorkshire, UK
    Time before last service I had, the dealer recommended a fuel system additive (£20) as I was collecting the car. I said no thanks as I only use premium fuels which already have detergents in, the service guy said they had already put it in but as I didn't want it, no charge. They had actually overdosed it too as there was only a couple of gallons of fuel in it at the time, it wasn't running 100% until I filled the tank again to dilute the stuff. When I took it for the last one I told them, before the service, not to put any fuel system cleaner in.
    JorgeLA, krmcg and alanclarkeau like this.
