Adjusting Bluetooth mic level in 2024 Prius XLE
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by LBHough, Mar 11, 2024.
  1. LBHough
    LBHough New Member
    2024 Prius
    Just got the new car and its great, except my wife and I both have to SCREAM at Apple Maps to tell it a destination for car play. I have talked successfully on the wireless Bluetooth through my iphone. I cannot find ANYTHING in the manuals or online. I did learn that the BT mic goes through the DCM, but can I turn up the volume ? Please note that if I scream the destination it works (so its not disconnected). I don't have the JBL audio if it makes any difference. Thanks for any help. LBH
  2. aforkosh
    aforkosh Active Member
    413
    262
    Oakland, CA
    2023 Prius
    The easiest way to work with directions in Apple CarPlay is to pick up the iPhone and set it up in Apple Maps. CarPlay will then use what has been set. This also allows you to set up more complex routes by adding intermediate points if necessary.
  3. HacksawMark
    HacksawMark Active Member
    442
    287
    Oregon
    2023 Prius Prime
    XSE
    What phone do you have? With my 12 Pro Max, it works fine. No screaming required.
