Adjusting the amount of recuperation when freewheeling
Discussion in 'Gen 3 Prius Accessories and Modifications' started by mbait, Oct 11, 2017.
  1. mbait
    mbait Junior Member
    US
    2015 Prius Plug-in
    Is it hard (if possible at all) to adjust the amount of recuperation in 2015 PIP in such a way, that when I move my foot off the pedal and let the car glide, it would engage 100% of recuperation? If you ever drove a Volt, you should understand what I mean.
    51,155
    no, it is what it is. check the threads on using b mode.
    Dylan Doxey and jerrymildred like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    What @bisco said. ;)
    If you want to regenerate more than what you get from coasting (and therefore create a little more heat in the wires) just move that right foot over the the other pedal and modulate it to where you want it.
    Tip on the cruise control: if you're using the cruise control, holding down on the stalk regenerates pretty aggressively, too. But situations where it's both needful and safe seem pretty rare to me.
  4. fuzzy1
    10,335
    Have you tried putting the car in 'B' instead of 'D'?
    This isn't such a good idea in HV mode, just EV. And while I don't yet have any plug-in car, comments seem to indicate that it works quite well on the 2017 Prime, better than on the 2012-2015 PiPs.
    Dylan Doxey likes this.
  5. Mendel Leisk
    40,586
    Wouldn't that be imposing a lot more drag, slow you inordinately? There's no free lunch, it's a balancing act.
    Just editorial: "regeneration" is more appropriate than "recuperation" I think. You might be able to edit the title too.
    jerrymildred and fuzzy1 like this.
  6. bisco
    51,155
    my favorite is remuneration.;)
  7. Mendel Leisk
    40,586
    I'm prone to regurgitation.
  8. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    …sounds like you really could do with a Saab 96 (with the free-wheel device) (…see threads passim, or wiki) ;)
    Jayw13702 likes this.
  9. jerrymildred
    11,517
    14,137
    Tampa, FL
    I hate it when that happens!! :eek:
  10. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Besides using B mode, the amount of regeneration can be increased by using the brakes. I maximize my regeneration by braking early and lightly enough keep the HSI in the CHG portion of the indicator. It would be nice to have some paddles at the steering wheel to engage this.
  11. jerrymildred
    11,517
    14,137
    Tampa, FL
    Same here. I like being able to modulate the brakes to use as little as possible and still stop in time.
