Adjusting windshield washers
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by roderunner, May 16, 2010.
  1. roderunner
    roderunner Junior Member
    new mexico
    When I got my car back from regular service and a car wash, I noticed the windshield washers were out of position. To remedy this I took a pair of sharply pointed tweezers a gently inserted each point into the two washer holes of each washer outlet (2 each per half windshield) and levered the washer outlet ball back into position. It took several iterations, but finally got both sides properly positioned.
    Anybody know of an easier way?
  2. vertex
    vertex Active Member
    670
    143
    new york
    2018 Prius Prime
    There is a special tool, but I did it similar to your method. Not worth the $$ and time getting the tool
  3. Patrick Wong
    18,200
    6,474
    I've used a needle to move the outlet around, but the OP's method sounds better.
  4. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I've used a paperclip on previous vehicles. Sometimes I had to squirt some WD-40 around the nozzles so they'd loosen up so that I could move them. Although, the tweezers, or maybe even a really tiny awl (isn't that the tool with the pointed end?).
  5. MJFrog
    MJFrog Active Member
    780
    266
    NE Oklahoma
    2018 Nissan LEAF
    A straight pin works great.
  6. a_gray_prius
    2,927
    782
    IL
    A toothpick will work too.
  7. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    I think I used a paperclip.
