Adjustment Required?
Discussion in 'Gen 2 Prius Main Forum' started by George Leatherman, Jul 26, 2025 at 12:04 PM.
  1. George Leatherman
    George Leatherman New Member
    Yesterday
    Alamogordo
    My travelings include going over a 5000 ft mountain in 15 minutes. New hybrid battery works great. But at the top or before the battery indication goes into the pink. When this happens I pull over and manually charge the battery as I don't like to drain the battery too much.
    Is there an adjustment or settings that can cause the system to charge the battery more aggressively ?
    The car does well otherwise. On flat ground it never goes below 50% (blue) and charges the hybrid battery well. No problems. New battery this year. Few minor problems (ie.. level sensor for headlights is warn out and occasionally it throws a (bad cat oxygen sensor).
    51,226
    there are not any adjustments available. battery charging is software regulated for efficiency, life expectancy and safety.
    did you buy a new, oem battery from a dealer? mountains can sometimes be a bit of a challenge for prius, especially an old one.
    they are not the most powerful cars in the world.
